i need your help guys
i have 98 camaro with this mods
( 1-7/8 LT headers, X-pipe, 750cfm Carb, TH350, 3.73 , K-member, 2900 lbs, 4500 stall, stock 241 heads, stock bottom, only cam, QA1 R type front shocks with 275 springs)
** i was run two cams, see my sign **
i need now please a good cam or set up to run low or mid 10's please
"CAM ONLY"
thanks
"CAM ONLY"
thanks
Damn, what you do to drop the car to 2900 lbs? You can try a T-Rex or similar spec'ed cam but I doubt it'll get you the extra power you need to get there. There's always milling the stock heads to bump the compression. Still considered stock.
Personally, I recommend just throwing some AFR's or Trickflow heads on there to get the most out of your set-up
the ms4 probably isnt working the best for your intake. I'de recommend giving one of these vendors a call and speak w/ one of their guys about the cam specs for your intake setup specific to your intake. The camshaft profile is going to be different for a carbed intake.
