What is the best way to build your cage in the back of the car?
Im getting ready to put a new cage in my car. I was wondering what is the best way to do the cage in the rear of the car? I currently have my old cage running from the hoop to the back of the car and have them connected to a bar accross where the t top holders were. If anyone has any pics please post up or ideas. thanks.
Race your car!
I'd go as far as to do what Brian did, but take the bars all the way to the trunk, and run a 2nd set of small bars up to hit the long ones to tie it all in.
I'm doing something a little different (relocating shocks to the back/more centered on the rear, and putting a BIG anti-rollbar above the rear where the stock fuel tank usually is) and will be connecting it all together with some bars thru the top of the trunk floor up to the cage itself.
Car should be in the shop in the coming months, pic's will get posted once it's done.
ya look at some of the mini tub pics, with the side of the wheel wells cut you. you can see right acove the top of the coil pocket there some thick metal there. right behind the shock metal thats welded in. thats a good spot for a short rear bars, like the min 6-8point. and thats braced better for cutting the outside metal- the whole bumpstop of the frame right out. /so you can see the whole side of the coil/
i see guys do that for weight savings, or min tub. that dont have the cage tied in good above. and its like cutting half the frame rail out, cant be good
then if car needed a cute or faster then the 8.50 stuff, id go to the back on top of the frame rails like you said, with a bar going to over the coils. then you can put a coss bar inside the hatch between the stock rails. or outside the truck behind the bumper to mount the cute, push the car ect.
Race your car!
