Removing Cruise on a NON TCS car?
Ok guys I been working on my little car and I'm about to pull the cruise control and I was wanting to make sure that nothing else would be effected when I pull that little box from under the front driverside frame rail.
I looked to see if this would fit elsewhere better but I didnt notice anything, and I didnt see anything in the search.
somone put it behind/over the pcm.
but if you wnat to remove it just get a cable for a non asr/cc car. there is 2 part numbers. one ends 59 the other 60 ther for if you have a 98-00tb or a 01-02 tb with the bigger cam thottal shaft. if you have a aftermarket tb with 2 cable barrel holes you can use either.
achotrod thanks man
studderin, my car doesnt have the single throttle cable, its the dual cable design, the cruise control box for my car is under the fuse panels on the driver side of the car.. all I have to do is pull the cable and the box and its done on my car and I'll retain the original throttle cable.
