Drag Racing Tech
Removing A/C But want to keep heat
Old 10-18-2010, 07:05 PM
Quick99TransAm's Avatar
Default Removing A/C But want to keep heat
I want to remove ac but keep heat anyone done this and have any info I did a search did not find much
Old 10-18-2010, 07:17 PM
Tally TransAm's Avatar
just remove all the underhood ac **** and keep the heater hoses attached to the heater core
Old 10-18-2010, 07:35 PM
Blue2002SS's Avatar
This works, but I would also block the two open tubes left from the AC lines that go into the heater core.
Old 10-19-2010, 03:23 PM
camaroz28lt1at's Avatar
https://ls1tech.com/forums/drag-r...-c-delete.html
This might help...
Old 10-19-2010, 03:45 PM
wildn347's Avatar
im in the process of removing AC and retaining heat also, i have a question for the ppl who have done this. After I cut the AC box out i seen what looks to be a small vacuum line? Does this need to be plugged? or can you remove that line?
Old 10-19-2010, 04:55 PM
SS4Luck's Avatar
I can udnerstand wanting to keep the heat, but whats the point of deleting the a/c then? I took the whole thing out. MOST if not practically all of the weight removed was heater stuff and behind the dash ducting
Old 10-19-2010, 06:02 PM
had to make room for the turblo build. never used the ac anyways, but during the cooler months i definitely cant live without heat
Old 10-19-2010, 07:16 PM
venom99's Avatar
delete it all and get a mojavee heater it weights a few pounds but will keep you warm
Old 10-19-2010, 08:13 PM
SSmoken's Avatar
i dont mind being a little hot. i drive my car in 100*+ heat index during the summer without a/c. But in the winter its a different story. i cannot stand being cold.
Old 10-20-2010, 06:33 AM
The Guy in MY 99TA's Avatar
I can deal better with cold than hot... but uhhh I'm not gunna sweat in the summer in dead still traffic
Old 10-20-2010, 04:45 PM
studderin's Avatar
i made a really simple heater, with a super light heater core bolted to the stock sqarill cage. so its quite and works off the stock controals. check my build thread for pics and info on it page 3-4 i belive
