Anyone have true rear coilovers?
Robbie did this on his SI car thats gone 11.03, and on a 10bolt too. His user is promod1955 I think, and hes one hell off a chassie guy check out his build thread on the car for pics. And were it went the 11.03, and some parts he was selling has some good pics, runs a fuel cell thats a givin.
Race your car!
Benefit of doing this is that you get a little better control over axle movement (think, shocks are further back now and the farther they get form the pivot point the more they move when the tire is closer to the pivot point then the shock is), ride height adjustments, depending on what type of bracket you use can be easily done as well, clearance, ease of getting to the shocks to make adjustments as well.
I'm in the process of doing this, and putting a HUGE rear swaybar in the car, also mounted to the same bar that spans the frame rails, and is tied into the cage.
Pics to come once it's done.
Well, honestly on these cars we don't run a coil-over on the rear that often. We'd rather have the option to run all of the stock suspension races, so we keep the coil-overs on the front, and run the "stock" set-up on the rear.
When we do go rear coilover, we use the 12" springs with AFCO double adjustables.
