Check Out The New Moroso LS1 Electric Water Pump
We have the privilege to install the New Moroso LS1 Electric Water Pump on our Camaro. Let me say its a really nice piece. They took a standard BBC electric water pump and made LS1 adapters.
Place the BBC WP over the adapters and its a LS1 electic water pump. Then all its needs is the AN lines to the remote thermostat housing then over to the radiator.
We made an aluminum bracket to mount the housing.
Since we were redoing the front end of the Camaro we replaced the factory radiator with a smaller Griffin rad.
We also used Moroso's vacuum pump with there LS1 drive kit.
Have the pump set at 12-13 inches.
The car revs so much faster now. Have to watch it when we do the burn out.
We used -16 AN lines and the water temp does not go over 180 at all. Its flows alot of water.
Here are some pictures of the Camaro in our booth at SEMA.
Race your car!
Nice looking water pump. The vacuum pump looks good too.. has moroso come out with a bracket that will attach the pump to the head, or just to their water pump? Last time I talked to anyone there, they had a bracket that was going to bolt to the passenger's side head to mount the pump... haven't heard anything about it though.
Maybe they'll have one at sema?
Ya they sell just them, thats kind how the idea started for using a BBC. Before they had a LS pump of there own to fit.
http://www.moroso.com/catalog/catego...?CatCode=29300
part number 63615
Fits: GM LS Series Engines
Adapts a BBC style electric or eonventional water pump to LS series engines
Eliminates the bulky LS water pump with a more compact, cost effective pump
Since BBC water pumps have been around for years,many different drive and pulleys are available and now can be used on a GM LS Series engine
Kit includes: 2 billet aluminum adapter blocks (right and left), 2 pump adapter plates, fasteners, Viton O-rings, and high flow –12 AN fittings
Requires the use of a remote thermostat housing such as Moroso Part No. 63425 or 63426
Now that came out with a specific LS full setup
63566
part number 63615
63566
