Drag Racing Tech
Anyone running just an alternator? (no wp, ps, etc)
Old 12-15-2010, 12:01 PM
Luke Skyjacker's Avatar
Default Anyone running just an alternator? (no wp, ps, etc)
I would love to see some pics and or info on a alternator only setup. How did you do it? What belt? I have a 2006 lq4 so if I can keep the stock balancer that would be cool.
Old 12-15-2010, 02:12 PM
Reject's Avatar
http://www.speedinc.com/cont.cfm?cid=C0000531
Old 12-15-2010, 03:20 PM
5.3LJimmy's Avatar
^^^^that BMR relocation kit works good in an fbody, but may not fit if you have the engine in something else. It also spaces the alternator the correct distance from the block for the f-body balancer. It may work with some spacers for the truck style, but I'm not sure.
Old 12-15-2010, 03:44 PM
Reject's Avatar
https://ls1tech.com/forums/drag-raci...cket-6-0l.html
Old 12-15-2010, 10:01 PM
DOINSND's Avatar
Here is a pic. The idler pulley by alternator, I just changed out to a serpentine. Its hard to see it only goes around Alt. I'm pretty sure this is the truck tensioner. The belt I used is from Auto Z part # 550K6 or
6PK1395
JUST DUNE IT
Attached Thumbnails Anyone running just an alternator? (no wp, ps, etc)-img_20101119_171139.jpg
Old 12-15-2010, 11:14 PM
minytrker's Avatar
I run just an alternator with a 3 rib belt with no tensioner at all. It is a pain to get the belt on but once its on its fine. I have been racing like that for over years, never had a problem .
Old 12-16-2010, 01:38 AM
nemss1's Avatar
are you talking about just the belt around the crank pulley and alternator only? yes i can be done. the BMR bracket works really good on that. im assuming you are planning on running an electric waterpump
6PK1395
JUST DUNE IT
honeslty, you dont even need the idler there. i did the 'short belt' mod (no idler) and have never had a prob with issues of not enough belt-wrap for the waterpump. plus i cant see the flat side of the tensioner against the ribbed part of the belt being a good idea
Old 12-16-2010, 01:49 AM
nemss1's Avatar
Old 12-16-2010, 09:59 AM
I'm planning on running a setup like this but on either a truck or fbody pump. I'm sure I will have to make another bracket to mount the motor as it looks like the location in the pic would conflict with the upper rad. Hose.
[IMG]http://www.jegs.com/images/photos/700/720/720-4433.jpg[\IMG]
What would the desired alternator be that would work with the BMR bracket? This is going on a pro street style car and I'd enjoy the ease of a single wire setup without a ton of drag from the alternator itself.
Old 12-16-2010, 10:07 AM
tim99ws6's Avatar
I am running just an alternator. One thing I did NOT want was a fugly *** alternator mounted high on the motor to f up the look of my engine bay.
There were two options for me:
AEIcnc.com
http://www.aeicnc.com/lsmocoalki.html
Also bought into a East Coast alternator "super mini". Had slightly more power output than AEI's but meant i would have to make my own bracket.
I can say going both ways i had enough room to mount it low like the AEI and also run reverse log turbo setup.
Old 12-16-2010, 11:54 PM
droksformula's Avatar
I too was looking at that setup, but I've been told that 55amp is way to small, especialy when using an underdrive pulley and twin fuel pumps.
Old 12-17-2010, 07:19 AM
Demonicbird00's Avatar
heres mine
-brandon
Old 12-17-2010, 08:48 AM
tim99ws6's Avatar
Have you actually sat down and measured out how much amperage you are using, or just guessing? The Underdrive pulley really has nothing to do with it, as you get a custom size pulley from AEI that will match up to whatever diamater crank pulley you have. Notice in the above pic, they mocked that one up based on a Summitt UDP.
Old 12-17-2010, 10:13 AM
minytrker's Avatar
I used the stock alternator bracket, my method was free.
Old 12-17-2010, 05:19 PM
nemss1's Avatar
as did i. ill pull up a pic
Old 12-17-2010, 05:21 PM
nemss1's Avatar
Old 12-17-2010, 06:04 PM
philsblwnz28's Avatar
Whats the part # on that belt and did you gain any power from doing this mod?
Old 12-17-2010, 07:35 PM
studderin's Avatar
you guys are missing that point that he has no WP. thats just the short belt mod.
Old 12-17-2010, 10:38 PM
DOINSND's Avatar
[QUOTE][honeslty, you dont even need the idler there. i did the 'short belt' mod (no idler) and have never had a prob with issues of not enough belt-wrap for the waterpump. plus i cant see the flat side of the tensioner against the ribbed part of the belt being a good ideaQUOTE]
NEMSS1- If you read the post I changed out the smooth idler pulley to a serpentine pulley! That is just the way I set it up for my application.
Old 12-17-2010, 11:46 PM
Never measured, just figured if the stock is over a 100, 55 would not be enough even with the correct size pulley. In my case at least, ewp, fuel pump x2, ewp for a2w ic, factory monsoon stereo, etc.
Quick Reply: Anyone running just an alternator? (no wp, ps, etc)
