Wolfe racecraft mini tubs with a 30" tire??
We just recently mini tubbed my car with a wolfe racecraft mini tub kit. Curious if I can fit a 30x12.50 et street or a 315/60R15 et drag radial andstill sit the car down pretty low?? I have purchased a moser 9 inch narrowed 3 inches on both sides and running a 15x10 5"bs wheel. and info or pics would be very appreciated.
a 315/60/15 should fit very easily, at least I hope so cause thats what im running when I finish my mini tubs. Narrowed 3" should be pretty good, cant think of teh offset right now but even if its close you can either cut or roll the inner lip of the quarter.
As for a 30" slick im not sure, I know the wolfe website specifically names a 29" but I think it will be ok. Maybe someone with their tubs done could lend some advice lol
PM JL or im sure hell chime in. I know he is planning on running a pretty tall tire this season (or he was when i was talking to him about suspension help) and im pretty sure he has the wolfe tubs
Race your car!
But, I am making enough room for a 33x10.5W tire. No, a wolfe won't do that. Full 40 inch tub going in the car, outer and inner tub is coming out, control arms are getting shifted inward, bump stop and all that are going away as well.
A 315 tire will tuck in with a wolfe tub fine, 30 inch slick will as well.
fwiw I'm starting off with a 30x10.5 hoosier bias slick.. I "think" that wil be plenty for what I need, but if it's not, I will go strait to a 33x10.5x15W m/t tire. Honestly, I don't think that will be needed though.
It's got coil overs in the front. Wolfe adjustable upper spring mounts using a QA1 10" spring in the rear. He also raised the rear of the trans tunnel for more torque arm clearance.
There 275lb springs in the front and 150lb springs in the back. That'll make for one nasty looking camaro.
Offset
What did you have to do on the backside of your wheels for everything to clear? I like the way they tuck but my rear is only narrowed two in per side.I was thinking I need a 6" bs but not sure if I will have problems on the backside. I know it will take bfh and maybe remove bump stop. I want the most rubber I can possibly fit without sticking out of the wheel well
Can you keep the backseat with a mini tub? Sorry for the dumb question. Oh, and my back seat doesn't have the skeletal structure inside it, just the cushion only so it doesn't use the brackets to hold it in place, just large velcro strips. LOL Got 2 boys so had to have something and keep it light still!!
I want to know this too haha! I want mini tubs and deeps...looks bad *** with wide meats!
