Drag Racing Tech
What are your dr times h/c m6?
Old 02-15-2004, 11:48 AM
n2o
n2o's Avatar
Default What are your dr times h/c m6?
I have not ran my car at the track since the heads and cam, and I was wondering what to expect. The rundown: stg 2 5.3 heads 224 cam 17in. nittos and (12 bolt)4.11s, lca, hals, etc. What should I be on the path to?
Old 02-15-2004, 12:52 PM
chrismcdaniel's Avatar
A bigger cam
Old 02-15-2004, 01:01 PM
n2o
n2o's Avatar
probaly right
Old 02-15-2004, 01:47 PM
mike c.'s Avatar
i'de like to know if you have a 12bolt,why are you running nittos? i went from 275/40/17 nittos to 305/40/16 m&h race masters muscle car tire and gained 4 tenths in the 1/4mi. if you can hook you have a 11sec. car easy.
Old 02-15-2004, 03:41 PM
n2o
n2o's Avatar
I am hoping for some mid 11's as the car went 12.7's on stock radials with only bolt-ons. The car is also a full stock weight (stripper). I may or may not put it on slicks but def. not the first trip to the track.
Old 02-15-2004, 08:54 PM
n2o
n2o's Avatar
Also I am planning on doing a 90mm lsx intake, I am looking for a way to get in the low 11's n/a.
Old 02-16-2004, 01:41 AM
AINT SKEERED's Avatar
My car has ran 11.69 @119.39 with 16 inch drag radials. Today(sunday) at Hattiesburg with 4.30's in the car now, I could not get as good a 60 ft. with the Nittos. I ran a 12.07 @ 116.4 mph and switched to et streets and left the line at 6000 rpms and could only get a 1.69 60 ft and ran a 11.68@117.94. This is a new best and the track was not doing as well as it should have as no one was hooking as good. I figure when the track is hooking right I can do better then that on Nittos as I usually pull 1.70-1.75 60 ft.s on Nittos.
Old 02-16-2004, 07:00 AM
n2o
n2o's Avatar
Mid to low 1.7's are unheard of on these little Alabama tracks with a manual trans. f-body. I'm just ready to go to the track. AintSkeered, do you feel that your 4.11s are a help or hurt to your times? I haven't been able to pull a very good 60' with them, maybe it's the fear of my spec 3 it seems like it won't really hold up that well.
Old 02-16-2004, 08:58 AM
IF you are going to only run drag radials, Then 4.10's are awsome. I wanted to try the 4.30's and see how they would 60 ft with the Nittos but had no luck at Hattiesburg yesterday(too cold). I would recommend atleast a BFG for 4.30's if you are over 115 mph crossing the traps. With the Nittos, my shift light came on in 4th about 200 feet before the end of the track. The Nittos work great with 4.10's at almost any track I go to, I pull low 1.7's and a best of 1.67 and I know the car has a lot more in it on a good track day if I could run behind some big tire cars . 1.69 was the best I did leaving at 6000 rpms On 26x11.5x16 et streets.
If you go 4.10's , do a hard burnout and bring revs to 4000 at the tree and dump the clutch but dont mash the gas untill the car starts to jump forward . then mash the gas and hold on. I dont think I used this technique at the track on Nittos yesterday as I have not raced since the thunder shootout and broke my ankle .
Old 02-16-2004, 09:03 AM
By the way, the spec clutch worked flawlessly at 6000 dumps . You may need to adjust the master cyl.
