6 Spds+stock manifolds, how quick/fast?
Just wondering how quick these cars can run with boltons but stock manifolds. I've seen it posted that someone ran 113+, with an '02 fbody, with just a cat-back and lid. Most folks seemed to think it was I think anything is possible with these cars. What have you guys seen or run?
i went 12.57 at 113.72 with lid, catback, hyperteck, ftra, and 4.10 gears on street tires and 1.93 60ft. 1998 t/a m6
My mods & 3700lb race weight.
Suspension: Hal Qa1 drag shocks in rear, Metco lower control arms, Moser 12 Bolt 4.11's
Exhaust: stock manifolds, 3" Y-Pipe, 3" cutout & flowmaster cat back
Intake: SSRA, Granatelli Maf, SLP air lid & home ported TB
Tires: BFG drag radials P255/16/50's with 18 psi
Times in the sig, Fred
guess i am slow. i got a 12.80 with 4.10s, convo pros, lid, and free mods. then i when back to the track with 3.73s, bigger cam and could not do better then 13.10s. although, once i removed ehxaust to do a new motor and LTs i found a seriously melted converter. maybe thats were the power went. about how fast can they go, i personaly saw a M6 ram air go 12.60s NA and 11.30s with a TNT. he did not say how much he was spraying or if the cats were gutted but i did see the complete stock exhuast on it.
I ran a 12.37 @ 112.8 mph but I doubt I could do that too many more times without either trashing the stock clutch or stock 10 bolt/posi. That was through the full stock exhaust with gutted cats and a cutout. The clutch doesn't handle the drag strip too much any more. Mods are in sig. That was also running with E/T Drags on stock rims and Draglite skinnies up front.
12.57@113.9 on 275/40/17 nittos, 1.95 sixty, full raceweight, lid, cutout and 160 stat, and !rear baffles. Air temp was 46 and humid was 55%. Several other 12.5 and 12.6 that day. (would have been 12.4 or 12.3 but on my 1.87 sixty, trans deceided to break and not go into 4th)
2001 ws6
2001 ws6
I went 12.18@112.95 with a 1.77 60ft. The mods were weight reduction, 4.10 gear, Qa1s all four corners, 315/35/17 Nittos, complete BMR tubular k-member, Mcleod clutch, pro 5.0 shifter, Lous short stick, lid, modified ram air, mini LS1 Edit. Launch@3500. No heads, No headers, No cam.
