Drag Racing Tech
Will this get me there?
Old 02-17-2004, 06:36 PM
ricekillman's Avatar
Question Will this get me there?
12.9s Cutout, ASP pully and ported throttle body? Current mods and times in sig. Thanks guys. If not what will.
Old 02-17-2004, 07:02 PM
banks01ws6's Avatar
Actually, you could run 12's now with those nittos. You should be able to at least cut low 1.9's if not 1.8's. Smoke them in waterbox for 8 seconds, about 17psi. Dump clutch at 3k, if she bogs launch 3400 next time, if she spins 2700. Sometime as high as 4300!!! Once you cut low sixties, your time will drop dramatically. But with the asp and cutout, combined with good weather and low sixties, you will see 12's all day long. hope this helps.
went from 13.5 in heat of summer to 12.5 with nothing more than winter, nittos, and about 20 passes at the track.
banks
Old 02-17-2004, 09:58 PM
n2o
n2o's Avatar
Smoke them in waterbox???????????? If you still have the stock master cyl. that may be your problem.
Old 02-18-2004, 01:48 AM
Nah I've got the 01-02 master, but I definantly think a better 60' should help. The 13.3 run was with 3500 rpm dump with nittos at 18psi, she bogged. Next time i'll rev her up a bit more. Thank god to the stock rear end, hasn't let go yet.
