Drag Racing Tech
Connecting a light weight battery?
Old 02-27-2004, 11:16 PM
critter's Avatar
Default Connecting a light weight battery?
How do you all connect your Hawker/Genesis/Odyssey/SVR/etc batteries? Seems like most are 5 or 6 mm (look like bike batteries) and stock connector bolts are more like 3/8". I see you can get screw in posts which would work if I cut the ends off the stock cables and put post style connectors on, but I hate to do that. Another thought was to make an adapter to bolt the stock cable to that would then bolt to the battery. I can't find any brass, maybe aluminum would work. Ideas?
Old 02-28-2004, 01:34 AM
TwoFast4Lv's Avatar
mine came with bolts
I am revamping the entire system with ford relay and kill switch in the back. They are going to make me put it in next year anyways so I just move the battery to under the N2O Bottle in tha spare well
I should have pice in the next week or so
Old 02-28-2004, 07:35 AM
WILWAXU's Avatar
Thunder sells an adapter that allows you to use the stock terminals.
Old 02-28-2004, 09:59 AM
critter's Avatar
Thanks! That is just the ticket! It is, however, sickeningly obvious Just drill and tap the Hawker/etc GM posts 3/8-16
Old 02-28-2004, 11:14 AM
Kent1's Avatar
I have a hawker battery and I removed the original screws from stock cables. Then ran hawker battery screws thru stock cable with two washers on inside and outside of cables and screwed into hawker battery with cable. Battery was layed on side in battery for this procedure.
Old 02-28-2004, 09:54 PM
critter's Avatar
Even better. I wondered if that would work. This way you don't have to buy adapters.
Old 02-29-2004, 06:39 AM
WILWAXU's Avatar
Yup.. that would work too. I went the adapter route because I swap my batterys for the track/street. With this setup I don't have to fool with changing th bolts each time.
