Drag Racing Tech
Went to the track and was not impressed.
Old 03-05-2004, 05:01 PM
2_wacko's Avatar
Angry Went to the track and was not impressed.
I went to WestTexas Raceway Test and Tune last saturday and I was not impressed at all . My mods are in my sig and I was not having any launching problems at all. The Nitto Dr's hooked great my runs felt great also shifted fine. I know I am a better than average driver. I launched at around 2500 rpms because I was babying the rearend I have heard some people have broke there rearends with one good hook on Nitto's. I did not want to have get a ride home from the track. Here are some things to take into consideration, First I had a near full tank of gas, spare tire and jack a few things in the back seat like my girlfriends purse and a few small water bottles.
I also drove the car to the track from my home its about 65 miles from my home to the track. I had a air tank to put air back in the tires after my runs to drive back home. The air tank was not in the car during the runs but everything else was i listed earlier. Also the wind was blowing about 15 to 20 MPH and the temp was about 65 degrese.
Here are my 2 runs.
Dial In-------0.00----------- Dial In--------0.00
Reaction-----0.9450----------- Reaction------0.9946
60 FT--------2.2264----------- 60 FT--------2.1921
330 FT-------6.2518----------- 330FT--------6.1632
1/8 ET-------9.4526----------- 1/8 ET--------9.3496
1/8 MPH------77.59----------- 1/8 MPH------77.35
1000ET-------None----------- 1000 ET------None
1000MPH-----None----------- 1000 MPH-----None
1/4 ET-------14.5212----------- 1/4 ET--------14.3736
1/4 MPH-----97.70----------- 1/4 MPH------97.83
Anyone know what I can do to run at least in the low 13's. Or was there anything that affected my time.
Old 03-05-2004, 05:08 PM
SSU Moderator
RyanJ's Avatar
The altitude affected your time. you'll simply need more mods to go faster.
Old 03-05-2004, 05:12 PM
Assassin's Avatar
your mph seems a little slow, what rpm are you shifting?
Old 03-05-2004, 05:30 PM
2_wacko's Avatar
I am shifting right at about 5900 rpm's. Should I try powershifting or will that just cause ware on the engine and tranny.
Old 03-05-2004, 08:54 PM
DrkPhx's Avatar
You say your car was hooking, but those 60 fts need some work. What is the zip code of the track so I can check the DA?
Old 03-05-2004, 09:42 PM
Fred99LS1's Avatar
I thought better than say anything, but dude your running on 7 cylinders. Maybe you popped a plug wire. Hopefully, it's that simple. Fred
Old 03-06-2004, 12:05 AM
2_wacko's Avatar
Zip Code 79735
Old 03-06-2004, 10:18 AM
DrkPhx's Avatar
I show a calculated DA of +368-ft. Here are the recorded temps from Feb. 28th at 11:53am. There was a strong SE wind of 24 mph. I assume the track faces east-west.
11:53 AM59.0 °F / 15.0 °C 45.0 °F / 7.2 °C 60%29.79 in / 1008.6 hPa 10.0 miles / 16.1 kilometers SE24.2 mph / 38.9 km/h 32.2 mph / 51.9 km/h
The DA wasn't a negative factor but the wind might account for some.The lowest DA correction factor NHRA has is for +1200-ft. If you use the 60-ft formula 1/10 reduced in the 60-ft time will reduce your 1/4 mi ET by .15 or .10 x1.5.
Remove your drive side floor mat and STAND on the gas pedal to make sure your are getting true WOT. I would also have someone Autotap your car and check for Knock Retard, WOT voltage for starters. Lower your PSI on the drag radials to 22 psi at the track. Your 1/8 and 1/4 mi mph is waay low for a LS1, souble check all plug wires.
Finally practice, practice and practice driving at the track. The driver mod is a very important one.
Old 03-06-2004, 12:02 PM
DD966's Avatar
2.2 60ft w/DR's ? Something's amiss. I recorded a 2.08 60ft (1500 launch) on my best 1/4 mi., and I have the stock street tires. Power shifting is NOT the solution here. What gas are you running? I would defintely check the intake side of things first (from the air filter to the TB) perhaps you sucked up something that's restricting the flow. Then I'd check the plugs. If that all looks good I'd get it dyno tuned (LS1 Edit). Much can determined, and adjusted, there. Good Luck to you.
