Drag Racing Tech
PP heads & TSP 231/237 track results
Old 03-06-2004, 10:58 PM
Y2KSS's Avatar
Default PP heads & TSP 231/237 track results
This was my first time out with the PP LS6 style heads and TSP cam. The car wouldn't hook hard on the 10.5 ET streets. My other mods are a TCI 3800, 3:73 gears, Pacesetter LT's and LS6 intake. Here is my best time. This was on a 1000' foot track.
R/T-------.527
60'--------1.617
330'-------4.730
1/8 ET-----7.376
1/8 mph----94.49
1000'-------9.603
1000' mph---108.21
Old 03-06-2004, 11:22 PM
mshadow's Avatar
Full weight car?
Any other mods suspension? other bolt ons?
Im doing the exact same setup in July so I just wanted the details.
Old 03-06-2004, 11:49 PM
Y2KSS's Avatar
The car is full weight right down to the spare and jack. I also have a ASP pulley and a x-pipe true daul exhaust. I think I will pick up some with a dyno tune and a few suspension parts.
Old 03-07-2004, 12:01 AM
93octane's Avatar
Nice. I am really liking the numbers of the 231/237 cam with stock heads, as well as LS6 style heads. I can't wait.
Do you have any video clips of your car?
Old 03-07-2004, 12:08 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Great runnin!!! Keep workin on those 60's!! Maybe its time to swap to a 4400 so it can really leave hard
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 03-07-2004, 01:09 AM
Jammer's Avatar
Another union track I see...I hate when they go home at 3:30 and never return to finish the track.
Old 03-07-2004, 01:22 AM
mikemodano9c's Avatar
with a 94mph trap im guessing you would have ended up trapping about 118 or so in the quarter???
i did 93 cam only with a 228/230/112
just figured your setup would be good for more?
Old 03-07-2004, 01:52 AM
Beast96Z's Avatar
He shut off at the best part. The cam makes most of it's power up top and it should have been just gettin good when he got out of it.
Old 03-07-2004, 01:55 AM
heh...i didnt even know they had 1000ft tracks...whats another 320 feet?
Old 03-07-2004, 02:01 AM
Beast96Z's Avatar
A little bit faster.
Old 03-07-2004, 09:03 AM
Y2KSS's Avatar
The car was spinning pretty bad and it was kinda hesitating between shifts. I'm gonna try some real slicks and try to tune on the shifts a little too. It should pick up a couple of tenths at least.
Old 03-07-2004, 09:41 AM
StreetStalkerZ's Avatar
Good runs with the new setup. You ever come down to prescott raceway (1000ft.)? I usually try to go 3-4 times out of the year up there since the track hooks real good.
Old 03-07-2004, 09:55 AM
Y2KSS's Avatar
Actually, that is where I went yesterday. What car do you have, I may have seen you there before?
Old 03-07-2004, 11:53 AM
LS1TECH Sponsor
foff667's Avatar
nice #'s
Old 03-07-2004, 04:23 PM
CHRISPY's Avatar
Nice numbers, probably mid 11's in the 1/4
Old 03-07-2004, 04:51 PM
White 99 Z28 with weld draglites.
Old 03-07-2004, 05:50 PM
7 Second Club / STF Veteran
68maro's Avatar
multiply your 1/8 by 1.58 and it'll give you a close estimate of your quarter times. works in reverse to for your quarter to 1/8th times if you divide. so you ran about a 11.64 in the quarter. try it with your times it's usually very close of an estimate
Old 03-08-2004, 07:41 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Nice times.
I would guess mid 11's also.
Coach
Old 03-08-2004, 03:23 PM
CamaroCain's Avatar
R/T-------.527
60'--------1.617
330'-------4.730
1/8 ET-----7.376
1/8 mph----94.49
1000'-------9.603
1000' mph---108.21
You need a higher stall converter and some ET Drags
Are these the only bolt-ons you have?? Loose the spare tire and jack, rear seats, and run with close to 1/4 tank of gas. Have you removed the front sway bar yet? Maybe some skinnies on the front would help too And yes, the suspension could use some work too, if its stock. You'll get there
