230/236 107lsa cam results (track and dyno)!!!
Heads are stock 2001 ls1 heads. Car is an 01 SS m6.
Cam: TR230 Intake Lobe/Comp XE 236 Exhaust Lobe 576/574 107lsa (cam doctor) 107icl.
This includes two different days at the track and one different day at the dyno.
Dyno numbers are 392rwhp and 377rwtq through a 4.11 geared, 33 spline, moser 12 bolt and full exhaust.
Day 1 at track: All runs made with 17x9 fronts and 17x11 nitto drs rears and a 3590 raceweight.
Best: 60' 1.96x
1/4 11.98
mph 119.08
Day 2 at track: First ever run with e.t. streets on 16" trans am wheels. No sway bar or strut tower brace for this run. Raceweight is 3545
60' 1.69
1/8 7.44
mph 93.44
1/4 11.62
mph 117.98
I kind of short shifted this run from 1-2 and 3-4 as this was the best launch I'd ever had and didn't want to miss it by banging of the 6700 rpm rev limiter. My tach cannot keep up with this cam. I shifted from 1-2 at about 5900-6100 and 3-4 about the same. This cam likes to be wound higher. I think this is the reason and the only reason for the difference in mph.
Best: 60' 1.96x
1/4 11.98
mph 119.08
60' 1.69
1/8 7.44
mph 93.44
1/4 11.62
mph 117.98
Last edited by DAPSUPRSLO; 03-10-2004 at 01:55 PM. Reason: Forgot to say this was on stock heads.
I think it peaked around 6200 if I remember correctly. I will have to check with Jeff (GranyShiffting) and my sheets sitting at home though. I normally shift at 6600 (limiter is set at 6700) or so but it is hard to tell because my tach is not very accurate. As I said before though, I did not shift at 6600 when I ran on e.t.s
Originally Posted by Phil99vette
Who did the tuning?
Phillip
Phillip
