Nitto's slipping on stock rims
I have 245 50 16 nitto dr's on stock trans am rims...went to the track the other day with 19-20 psi in them and pulled a 1.73 60ft with a SS3800 yank converter. I marked the tires and after about 6 passes both tires slipped about 3 inchs on the rim. Besides using screws is there any way to keep them from slipping on the rim??? Thanks
Ya I have heard of people going high 1.5x's on nittos....but mine are slipping...as a matter of fact one of my buddies 2001 5.3 silverado truck with nittos slipped on his rims as well and he only pulled a 2.22 60ft! some of you guys try marking yours and see if it happens. There must be a way besides screws to stop this.
go to a tire shop and have them put the that black glue on the wheels for sealing rim leaks - worked for me before with bfgs.
My ET streets have moved almost 180 degrees in 51 passes, most people probably dont notice because they dont check I only cut low 1.6 60's and they move quite a bit. I need to screw them one day..
