Drag Racing Tech
Those who have installed front AFCO's
Old 02-18-2012, 05:51 PM
djfury05's Avatar
Default Those who have installed front AFCO's
Did you weld the upper AFCO mount to the upper a-arm or just bolt it on? The directions say you can weld it on or bolt it on so I am debating welding mine on or not if there is any benefit to it.
This is what I'm talking about. These are Westtexasbuff's pictures.
Old 02-18-2012, 08:59 PM
Coal Mining Director
onfire's Avatar
I would guess it depends on how much street driving you do. I marked mine with a white paint stripe and just bolted them in. Never moved after 30 passes at the track and a few miles around town.
Took the whole suspension off this winter to refresh and spot welded them since they were apart.
I would weld them, Just make sure they are angled correctly first for the shocks.
Old 02-19-2012, 12:23 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
Just bolting them in should be fine, but it sure wouldn't hurt to add a tack weld to it as well to keep if from potentially rotating. Like said before... make sure you line it up first.
Old 02-19-2012, 09:00 AM
djfury05's Avatar
Sounds good once I get it on the car I'll put a couple tacks in there.. Thanks!
Old 02-19-2012, 09:22 AM
95killerz's Avatar
I welded mine in I don't really think you need to but if the welder is right there can't hurt
Quick Reply: Those who have installed front AFCO's
