Drag Racing Tech
Using stock steering rack wo the pump in a race application
Old 03-04-2012, 01:28 PM
ls1ya's Avatar
ran mine without the pump for 2 years. No problems. Just leave the tensioner and run a shorter belt.
Old 03-04-2012, 01:33 PM
RacerXLs1's Avatar
Good info here guys, I'm glad this came up...
Old 03-04-2012, 09:13 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by dnkynrbk
someone post up a picture of how thier belt is looped
Mine is routed just like the picture posted
Old 03-05-2012, 06:57 PM
RENE'S RAGE's Avatar
Originally Posted by TurboStangJON
It allows you to swing the alternator in order to tighten the belt down. In other words you don't run a tensioner and the belt tension is adjusted like an old school belt setup. I only run an alternator so it works out pretty nice plus eliminates the weight of the factory bracket an any other useless pullies.
Thanks, I always wondered, because it's left in the same location.
Old 03-11-2012, 12:28 PM
dnkynrbk's Avatar
anyone have any other pics on how they ran their belt. With the no powersteering pump way. thanks
Old 03-19-2012, 04:29 AM
02sleeperz28's Avatar
Wish I would have known about this before I got my manual rack.
Old 03-19-2012, 04:49 AM
subhumanzz's Avatar
My belt is routed the same as pictured. Shifted at 7900 with no problems.
Old 12-28-2012, 01:03 PM
Camaro396's Avatar
I looped mine and have no issues turning it. Tougher than stock obviously but my GF drives the car just fine. Sounds like you have a rack issue.
Old 12-29-2012, 11:42 AM
1999transamls1's Avatar
It's somewhat better now, but it's pretty easy to turn right, but quite a bit harder to turn left, not sure what's up with it
Old 12-30-2012, 12:24 PM
MUSTANGBRKR02's Avatar
I think rackdoctordotcom makes a manual rack out of your stock one for cheap too.
Old 12-28-2013, 04:53 PM
StangEaterSS's Avatar
I would assume because the fluid is being compressed w nowhere to go in the one direction. Maybe drain the rack and run it wide open w no fittings like foggedz did. May turn easier.
Old 01-07-2014, 12:16 PM
  #32
manfred717's Avatar
Anyone have a pic of which lines to loop and did you guys drain all the fluid out?
Old 01-07-2014, 12:54 PM
  #33
DietCoke's Avatar
Open the rack up, cut off the hydraulic seal, put it back together and weld or RTV the ports shut. That way you aren't fighting hydraulic pressure. My rack is done like this and drives fine on the street. Much less effort then a looped rack
Quick Reply: Using stock steering rack wo the pump in a race application
