Why Is Concrete Better? - LS1TECH
Thread Tools Search this Thread
Old 03-05-2012, 12:43 PM   #1
HibachiZ28's Avatar
Question Why Is Concrete Better?
So one of my local tracks is being redone as I type this. They plan to open late this month. Their former track surface was your typical street style asphalt. It worked, but traction was always an issue for me. They are redoing the track with either 60', 700', or the full 1/4 mile in concrete. I have been told concrete provides better traction, but I am curious as to the reasons behind this - any links or info would be great. Thanks!
HibachiZ28 is offline   Reply With Quote
Old 03-05-2012, 12:45 PM   #2
Internet Mechanic
BlackScreaminMachine's Avatar
I have heard the same and I have a few good Ideas why but I am sure some experts will chime in and you will get your answer.
But def a good question for the forum!
BlackScreaminMachine is offline   Reply With Quote
Old 03-05-2012, 12:55 PM   #3
Tenured Member
SMOKY's Avatar
asphalt moves if you hook. concrete is alot more stable
SMOKY is offline   Reply With Quote
Old 03-05-2012, 01:20 PM   #4
2nd Gen Fl 'bird's Avatar
Concrete holds rubber better than asphalt. Rubber from burnouts, etc gets laid down and makes for better traction but, if you get out of the "groove" on a concrete track, where there is no rubber, traction is worse than asphalt. So, stay in your lane and go straight. Hope this makes sense.
2nd Gen Fl 'bird is offline   Reply With Quote
Old 03-05-2012, 01:53 PM   #5
Several benefits, the largest being it's stability, it is far more rigid even compared to an asphalt pavement designed for it. Have you ever noticed in high traffic areas - typically approaching a stop light - you get rutting and a ripple effect in the pavement? This is the asphalt actually moving between layers (e.g., base, binder, top)
As a Civil Engineer I design roads all the time, there are several different grades of asphalt with different types types of coefficients of friction use for a top coarse - typically a type 7 or type 6 if it isn't a superpave type. Depending on the concrete mix and how it was finished it can also have a different coefficient of friction which can be dialed in for a more aggressive friction type. We typically use a coefficient of friction to analysis the necessary degree of superelevation (banked slope on a turn) and the necessary distance for stopping - usually designed for wet conditions and bald tires in mind.
BanditTA is offline   Reply With Quote
Old 03-05-2012, 01:56 PM   #6
Zmg00camaross's Avatar
^^^ pretty good read.
Zmg00camaross is offline   Reply With Quote
Old 03-05-2012, 05:21 PM   #7
RacerXLs1's Avatar
Couldn't say it better
RacerXLs1 is offline   Reply With Quote
Old 03-05-2012, 06:22 PM   #8
Doug G's Avatar
You must be talking Cecil County Dragway
Doug G is offline   Reply With Quote
Old 03-05-2012, 06:31 PM   #9
HibachiZ28's Avatar
Thanks for the info, guys!
Quote:
Yes sir. Can't wait 'til it opens!
Old 03-05-2012, 08:35 PM   #10
Doug G's Avatar
Gotta get my LY6 clone to the machine shop and then it won't be long (I hope)
Quote:
Due to our resurfacing project the track will be closed for approximately 2 or 3 more weeks. We are hoping to be open by March 30th.
http://www.cecilcountydragway.com/index.shtml
Old 03-06-2012, 09:19 AM   #11
HibachiZ28's Avatar
Yep, I was talking to Jim (the owner) over on Yellow Bullet. Can't wait.
Old 03-09-2012, 05:26 AM   #12
Doug G's Avatar
More pics are up on YB
Old 03-09-2012, 09:15 AM   #13
6 & 8 Second Club
mrdragster1970's Avatar
I read a story years ago about the difference.
They had close up photo's and showed that concrete had a much higher contact area.
Even with the naked eye you can see there is more air gaps between the tiny pebbles.
It's even more evident when they do the magnification comparison.
mrdragster1970 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Worst track ever Sladester2 Drag Racing Results 7 09-16-2013 06:19 AM
Need Advice From M6 Guys who 3.42 to 4.10 Cvaught Gears & Axles 41 02-15-2009 09:20 PM
What e.t. difference with Drag wheels compared to stock? Dr. Jeckel Drag Racing Tech 27 04-08-2007 05:41 PM
concrete floor options? Woody99 Tools & Fabrication 14 11-27-2004 03:21 PM
4.125" bore with a LQ4 Block? tommy Generation III Internal Engine 19 04-22-2004 12:40 PM
Tags
aslphalt, cecil, cement, concrete, county, drag, dragway, good, project, race, racing, repaving, resurface, resurfacing, traction
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
