Do fabricated valve covers need to be vented? - LS1TECH
Thread Tools Search this Thread
Old 03-25-2012, 08:41 PM   #1
krissoto's Avatar
Default Do fabricated valve covers need to be vented?
Recently just put a set on my motor, and just wondering if they need to be vented at all? There are no provisions for one, just wondering what kinda things this may cause if I run them without any ventilation.
krissoto is offline   Reply With Quote
Old 03-25-2012, 08:42 PM   #2
krissoto's Avatar
Old 03-25-2012, 08:57 PM   #3
subhumanzz's Avatar
how are you venting crankcase pressure?
subhumanzz is offline   Reply With Quote
Old 03-25-2012, 10:57 PM   #4
94Z28rag's Avatar
You need to vent crankcase pressure somehow. I have a vent on both sides of my engine. Take the valve covers off, bore a hole the size needed, insert grommet and vent filter, reinstall.
94Z28rag is offline   Reply With Quote
Old 03-27-2012, 06:36 AM   #5
krissoto's Avatar
Thx for the input guys I appreciate it.
Old 03-27-2012, 05:29 PM   #6
Firehawk441's Avatar
Install AN bungs on both valve covers and vent the engine into a catch can.
Firehawk441 is offline   Reply With Quote
Old 03-27-2012, 08:33 PM   #7
krissoto's Avatar
I think im gonna run a single 12 an line to a catch can.
Old 03-27-2012, 09:13 PM   #8
great question.............and answers!
i think i bought the same valve covers............and i have been wondering the same thing.
heymoej is offline   Reply With Quote
Old 03-27-2012, 10:05 PM   #9
I bought those same covers and they kept leaking from blowing out the seal on the rails. The gasket would not stay in the groove for some reason so I sold them. Sure hope you have better luck
autokraft is offline   Reply With Quote
Old 03-28-2012, 09:05 AM   #10
6 & 8 Second Club
mrdragster1970's Avatar
What's the exact application??
You might consider a vac pump.
mrdragster1970 is offline   Reply With Quote
Old 03-28-2012, 05:07 PM   #11
armyboyatc's Avatar
If the car was going to see some street time then I would advise some sort of PCV system with a catch can.
armyboyatc is offline   Reply With Quote
Old 03-28-2012, 09:28 PM   #12
SSPerformance's Avatar
Quote:
x2 .
SSPerformance is offline   Reply With Quote
Old 03-28-2012, 09:42 PM   #13
krissoto's Avatar
would the -12 off one side to a catch can, not be enough? The car will see the street, but I have done some reading, and this seems to be the best option, If I need to vent both sides, I will but just wondering if it is necessary.
Old 03-28-2012, 10:01 PM   #14
Race your car!
You don't have to vent both sides, you can if you want to but the engine's pressure is pretty equeal. Only reason I have ever been given to vent both sides, was so the contaminents that are airborn, can leave from both sides of the engine since the heat and fumes rise, having a vent on both sides will help keep all of it out a little better. I can't say how much though.
I had a set of valve covers that had -10 bungs on them, so ran a -10 line, connected the 2 together with a T and then to a breather can like described above. If the bungs weren't already on the valve covers, I would have only put one on, fwiw.
Vac pump, if you keep the vacuum level at a reasonable setting, say 8 to 10 in, would be beneficial.
JL ws-6 is offline   Reply With Quote
Old 03-28-2012, 10:16 PM   #15
Quote:
That is NOT a cut and dry answer. It depends on how much crankcase pressure there is in a given application. An N/A engine with moderate cubes and moderate compression won't create the pressure that big cube, high compression, or power adder engines will. Start with one and go from there. DO NOT however "T" off your hoses into a catch can. Both hoses should have there own entry when using a single catch can.
Related Topics
Thread Thread Starter Forum Replies Last Post
Fuel tank venting Gregamuffin Conversions & Hybrids 7 09-08-2014 10:46 PM
Fuel return line question Houston_t Conversions & Hybrids 5 10-22-2012 07:32 PM
WORKING fender vents........ vroom_vroom LS4 Performance 17 03-24-2011 08:21 PM
changing non vented opti to vented cruzin94 LT1-LT4 Modifications 4 09-25-2007 11:20 AM
Need help with a/c vents blowing just threw the bottom 98HAVACTA General Maintenance & Repairs 14 07-14-2007 10:21 PM
Tags
bbc, bungs, catch, cover, covers, engine, fi, ls1tech, lt1, race, sides, valve, vent, ventelation, venting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
