Drag Racing Tech
battery cut off switch wiring...
Old 04-16-2012, 02:34 PM
StangEaterSS's Avatar
Default battery cut off switch wiring...
What gauge wire should be used to run from the alternator to my switch in the rear? I all ready have 1 gauge welding cable for my power from the battery in the back. and used some 1 gauge for the grounds also. just need to figure out how to wire so the alternator will not cause the car to keep running.
Old 04-16-2012, 05:07 PM
Formula Stocker's Avatar
Does your car have a switch panel? If so, I would run the ignition wire to the switched side of your cutoff switch to kill the car. I might be wrong but I wouldn't think cutting power to the alternator is gonna kill the car like u think
Old 04-16-2012, 05:46 PM
Old Geezer's Avatar
www.madelectrical.com
Old 04-16-2012, 06:48 PM
no switch panel but i'm sure i could find the ignition wire and splice into it.
Old 04-18-2012, 08:39 AM
5.3LJimmy's Avatar
I ran 4 gauge for mine and it charges fine. You need to run the alternator charge wire either directly to the battery or to the battery side of the cutoff switch.
Old 04-18-2012, 07:20 PM
Doug G's Avatar
This is the one I used ...
Quick Reply: battery cut off switch wiring...
