Drag Racing Tech
preloading oem rear sway bar
Old 04-17-2012, 06:39 PM
jgillen91's Avatar
Default preloading oem rear sway bar
1991 Camaro lq4
Been contemplating shortening the spacer between the sway bar bushings on driversside to help straighten up the launch.
I have own z28 rear sway bar with poly link bushings and Umi location spacer jobies for my 9" rear.
I know a anti roll bar would be ideal. But have any of you experimented with doing this.
How much should I shorten the spacer on the drivers side sway bar link as a starting point?
Thanks
Old 04-17-2012, 08:08 PM
TurboStangJON's Avatar
You may be able to preload it but I would think it would flex under load and foil your idea. Also, the urethane is going to move along with any other parts not designed to be used as an ARB. You can't make a stock sway bar into an ARB.
Old 04-18-2012, 03:23 AM
ren987's Avatar
I did it, and didnt notice a difference. Don't even waste your time. Get a proper anti roll bar and you will be much happier with the results.
Old 04-22-2012, 12:21 AM
jgillen91's Avatar
made my own today
1999 4wd blazer front sway bar. $40.00
1/2 rod ends/ jam nuts. $23.00
Misc steel. $30.00
Used existing sphon sway bar u bolts etc
$93.00!!!!
1/2 all thread . free!!!
Bar diameter is 1.310" roughly 33.5 mm
before
after
Old 04-22-2012, 12:35 AM
87silverbullet's Avatar
Good deal! Now you have to scale the car to see how much adjustment is going to be needed.
Old 04-22-2012, 03:45 PM
I'd put a tack on rearend/Spohn pads to make sure they don't shift under power. I'd also put a couple of tacks on the ones that you made to make sure they don't shift. I know they are bolted but once you start throwing power at it everything will try to move. What kind of power are you making? Good luck and keep us updated on the results.
Old 04-22-2012, 05:55 PM
jgillen91's Avatar
sounds like a good idea.
hopefully around 600fwhp
best 60ft so far is 1.531 and 10.97@ 124
Old 04-22-2012, 08:17 PM
Mighty Whitey's Avatar
Originally Posted by jgillen91
made my own today
Misc steel. $30.00
$93.00!!!!
before
http://i691.photobucket.com/albums/v...-06-10_131.jpg
after
http://i691.photobucket.com/albums/v...-18-40_116.jpg
http://i691.photobucket.com/albums/vv273/jgillen91/2012-04-21_18-19-45_788.jpg[/IMG]
http://i691.photobucket.com/albums/v...-19-30_889.jpg
I like your style!
I was just looking at my stock front sway bar and wondered if I could make it work on the rearend as well.
Glad there are other people out there that are willing to try something different instead of just pick up the phone and burn up the credit card.
Old 04-22-2012, 08:38 PM
jgillen91's Avatar
Thanks man I've been building alot of stuff recently. Motor mounts for my ls swap etc. Too bad I wasn't in the building mood when I bought my torque arm lok
Quick Reply: preloading oem rear sway bar
