Drag Racing Tech
Wiring up a MSD 2 step in 99 Camaro???
Old 05-02-2012, 11:54 AM
4U2NV-SS's Avatar
Default Wiring up a MSD 2 step in 99 Camaro???
Need a little help,
I understand how it works and I have installed the 2 step. I ran a wire into the car.
However I want to hook it up to the clutch switch and a push button switch on my shift.
Do I use the ground from the MSD box or the 12V wire???
On the clutch switch the lower switch has a green wire and a purple with white strip, which wire do I splice into before running to my push button?
I tested both wire with a test light and either showed power. I had the key on and the clutch pushed down, do I need to try to completely start the car before it the wires show power?
Thanks in advance!!!
Old 05-03-2012, 11:57 AM
4U2NV-SS's Avatar
Well I did some more research....
Looks like I need to use the blue ground wire from the MSD box to my push button then splice it into the purple/white wire on my clutch pedal.
Can anyone confirm this???
Old 05-03-2012, 12:34 PM
gconnoyer's Avatar
Yup thats how I have mine wired up.
Works perfect.
Tap the purple/white wire on the switch, and hook up the solid blue wires on the box
Old 05-03-2012, 02:49 PM
4U2NV-SS's Avatar
Thanks a bunch gconnoyer !!!
Old 08-17-2012, 11:48 PM
4U2NV-SS's Avatar
I did this today and my 2-step still did not disconnect until I let go of the button. Shouldn't it stop woring whn I let the clutch out???
Quick Reply: Wiring up a MSD 2 step in 99 Camaro???
