Drag Racing Tech
Which throttle cable and bracket to use on 4150 throttlebody?
Old 06-25-2012, 10:46 AM
second_2_none's Avatar
Default Which throttle cable and bracket to use on 4150 throttlebody?
Like the title says, which throttle cable and bracket to use on an edelbrock 4150 throttlebody? I did a search but could not really find anything specific. I seen a few people say an 80's model blazer, but I'm not sure if they are talking about the full size K5 blazer with a V8 or the S10 blazer with a V6? I'm also unsure of what bracket to use to hold the cable. Any help is greatly appreciated! It's the last thing I need to finish for the car to be completed.
Old 06-25-2012, 07:10 PM
Well I tried a cable off a 90 S10 4.3 TBI and that is way to long. I could really use some help on this to finish up my car.
Old 06-26-2012, 04:33 AM
jeeves744's Avatar
I have the accufab version but i just used the stock cable. Just made a little bracket to attach the cable to the tb.
Old 06-26-2012, 04:42 AM
Yeah I did that as well but it kept pulling the sheathing around the cable through and causing it not to go WOT.
Old 06-26-2012, 04:25 PM
RENE'S RAGE's Avatar
I just bought one off of here. I have not in stall it yet.
But the guy said it's from a Blazer. I think I remember everyone said a '86 s-10 Blazer
is what you want. The cable I have measures 34" end to end of the cables. And 25" from the firewall plug to the tb bracket plug.
I have a thread on here about the brackets, I like the AED 6600 also. The CSR bracket does not have the return springs.
Old 06-27-2012, 04:52 AM
Thanks man. Yeah thats way to long for me. I just bought a universal cable and cut it to length. It came out to 23" and some change from tip to tip. 24" would have been best but I cut it a little to short like a dummy. Yeah I seen your thread and like your bracket. Thanks again for the help.
Old 06-27-2012, 07:38 AM
Old 06-27-2012, 06:42 PM
blue99fbody's Avatar
i just used a cheap *** spector cable from auto zone and the brackets that came with my vic jr
Old 06-27-2012, 07:19 PM
armyboyatc's Avatar
Lokar and custom bracket here.
Old 06-28-2012, 10:45 AM
Yeah I went and got the Spector cable from AutoZone also and a cheap universal bracket from a local speed sho. All the brackets I have tried hit the cowl, so I'm going to cut the lower part of the cowl out more to have room for the bracket.
Old 06-28-2012, 04:42 PM
Just cut the cowl to the windshield. If your not going to use your wipers, cut the cowl all the way across, also.
What's what I did.
What hood are you going to use?
Old 06-29-2012, 06:34 PM
krissoto's Avatar
3rd gen camaro is what I used, fit perfect. They make 2 kinds. I believe one is tuned port, the other is TB.
Old 06-30-2012, 09:23 AM
What's what I did.
I dont have my wipers on any more but I dont want to cut all the way to the windshield because I want to keep the plastics on the cowl. I dont have an extended hood so there would be a gap and look funny if there was no plastic cowl pieces there. I have a regular VFN Sunoco hood. I did cut it back but to where I could still put the wipers back on and the plastics.
Ok thanks, I tried to get one from the parts store but they didnt have any so I just purchased the universal cable they had. If the universal dont work out I will get one from a 3rd gen. Do you know which cable it is though, the tuned port one or the TB one?
Quick Reply: Which throttle cable and bracket to use on 4150 throttlebody?
