Drag Racing Tech
AN Fittings Jegs or Aeroquip
Old 07-29-2012, 08:28 AM
RENE'S RAGE's Avatar
Default AN Fittings Jegs or Aeroquip
Need to plumb my Super Victor.
Are the Jegs brand AN Fittings as good as the Aeroquip, Russell, Earls?
Old 07-29-2012, 08:34 AM
Old Geezer's Avatar
We use Fragola from Summit...LOTS less on the $ side, good quality. Look up the pt numbers, then do a search on Summit. They seem to always have what we need.
http://fragolaperformancesystems.com/
Old 07-29-2012, 09:18 AM
SWeiser31's Avatar
If you can get your hands on the last issue of Hot Rod magazine, they've got a great comparison of AN fittings. Should be the September issue. I don't think they had the Jeg's brand but they did have Summit as well as Fragola and several others.
Old 07-29-2012, 09:39 AM
Timmy P's Avatar
I use the Summit brand. only issue I have had was binding up, we started to use their Nickle plated fittings and have not had a single problem. We use them on almost every car now. Easy on the budget and look great too
Old 07-29-2012, 09:53 AM
BES Stroked Nova's Avatar
using the jegs fittings with the racers discount they offer is nice. never had a problem with any of their fittings or hose. My WHOLE car is plumbed with it.
Old 07-29-2012, 10:14 AM
subhumanzz's Avatar
No problems with any of their fittings on my car either.
Old 07-29-2012, 10:32 AM
i6overboard's Avatar
XRP is the best i've used, the difference in these fittings is gonna be the life span, i've bought some cheaper fittings only to replace them because they start to bind when trying to remove them.
Old 07-29-2012, 10:44 AM
CBAR02SLP's Avatar
Default AN Fittings
^^^^^ This
You will find quite a difference in fittings and will see Earl's priced right with larger orficies (oh yes, and made in the USA!)...I use a lot of AN stuff and the article changed my buying habits. FWIW
Old 07-29-2012, 11:44 AM
minytrker's Avatar
Alot of the AN fittings are all made at the same place. I myself have all black jegs fittings on my car.
Old 07-30-2012, 04:18 PM
How do I get the racers discount?
Old 07-30-2012, 04:19 PM
That's the ones I want.
Old 07-30-2012, 04:20 PM
Originally Posted by JL ws-6
I've always used earls and summit stuff and never had any issues. I find a little dab of grease on them when assembling usually prevents any binding, fwiw
I was thinking alittle anti-sieze.
Old 07-30-2012, 04:29 PM
Firehawk441's Avatar
I've used them all. The only fittings I've ever had issues with were EARLS hose ends.
Old 07-30-2012, 06:16 PM
Thanks fellows!
Old 07-31-2012, 12:17 AM
gjohnsonws6's Avatar
I always use just a tiny bit of engine oil from the dipstick since its always within reach. I have been using Russell hose and fittings for years and never had a problem.
Quick Reply: AN Fittings Jegs or Aeroquip
