Drag Racing Tech
trans am guys with 4150tb what hood do u have?
Old 08-10-2012, 12:37 AM
89ROC-Z's Avatar
Guess i know what hood i'm going with! Looks great
89ROC-Z's Avatar
Where did you get those head lights?
Old 08-10-2012, 09:37 AM
Phoenix H.O.'s Avatar
if you're asking me about mine, i got them from breathlessperformance.com i'm not the hugest fan of them but they're good weight reduction. for a 2750 lb car.
Old 08-10-2012, 08:49 PM
89ROC-Z's Avatar
holy **** those lights are money....
Old 08-11-2012, 12:10 PM
RENE'S RAGE's Avatar
Originally Posted by Phoenix H.O.
the IAT is tied off to the side behind my driver side headlight with a zip tie and the MAP is in the back of the intake.
Did you drill and tap the intake for the MAP Sensor?
My Super Victor only has a 3/8" port on the pass side, that I'll use for the power brakes.
Thanks
Old 08-14-2012, 06:04 PM
IllusionalTA's Avatar
mounted map remotely, using a hose barb and a hose...
Old 08-15-2012, 04:17 PM
I still need to drill and tap the intake somewhere.
Or can I use a barb fitting off the Fast 4150 TB.
Old 08-15-2012, 04:22 PM
I just noticed your plumbing power brakes, I'd drill and tap another hole.. Easy enough.. Or use a cheap vac pump setup..
Old 10-19-2012, 06:58 PM
Pwebbz28's Avatar
Or do what the mustang guys do and get the manifold from Home Depot and run it off the 3/8 intake hole, and use the different outlets to feed all of your vacuum needs...It accepts 1/8 or 1/4 NPT fittings and use a flare on the other end...Done. Clean. and no drilling of any holes in the intake, which is stupid.
Old 10-20-2012, 09:18 AM
I'm not familiar with the Home Depot manifold.
Do you have a picture of it?
What is it basically used for?
Thanks for the info.
Old 10-20-2012, 09:28 AM
There's only one tap on a super Vic, I'd never share the map with something as large a draw as the booster.. I'd give its own source in the manifold.. Diff strokes for diff folks...
Here's something similar to what he's talking bout
http://www.pneumadyne.com/brass-pneu..._205-l-en.html
Old 10-21-2012, 03:39 PM
  #32
Thanks, looks like a brass adapter block.
Yeah, I would like for the map to have it's own port also, Right now I have the map coming off the back of my 4150 tb. Just under the blades of the tb.
I hope this works. I'm sure I'll have to go with manual brakes, before it's said and done. Just trying to get the car down the track this year.
Thanks
Old 09-23-2013, 07:39 PM
  #33
Rise of the Phoenix's Avatar
Kind of on the same topic, but what 4500 EFI TB would you recommend? Which one is going to be the best bet for the money?
Quick Reply: trans am guys with 4150tb what hood do u have?
