Drag Racing Tech
Ordered TA and subs!
Old 04-05-2004, 02:57 PM
CHRISPY's Avatar
Default Ordered TA and subs!
bit the bullet and went with the burliest pieces I could find
Here is what I ordered:
and
Hopefully after installing and setting pinion angle I'll never have to worry about it again
Chris
ps- Thanks to Speed Inc. For their prompt response!
Old 04-05-2004, 03:11 PM
The Juggernaut's Avatar
Do you have the BMR X-treme duty drag bar also?
Old 04-05-2004, 03:29 PM
CHRISPY's Avatar
nope, I thought about getting it but am going to use an airbag instead
Old 04-05-2004, 03:52 PM
gator's 99TA's Avatar
you went 1.50 on a stock tq arm and no subs? i assume you dont have a cage either.
Old 04-05-2004, 04:53 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Stepping up I see. Welcome to the darkside!
Coach
Old 04-05-2004, 05:16 PM
Get the drag bar,trust me.
Old 04-05-2004, 08:51 PM
CHRISPY's Avatar
I had a Random tech TA and a 6 pt rollbar when I went 1.50.
From what I have seen anything under a 1.5 will snap that RT torque arm or the tailshaft.
This should hold the 9's (with pwoeradder) I am going for next year and the 10's (all motor) this year
Old 04-06-2004, 04:21 PM
Cool man.
Good luck on the 10's. Maybe one day I will get a 10 second time slip with a F-Body Hot Rod also.
Coiach
Old 04-07-2004, 07:44 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
be sure to run your stock sway bar in the mean time, it does help... a little
Old 04-07-2004, 09:53 PM
CHRISPY's Avatar
Oh yes definitely, stocker will stay on
