Wolfe Adjustable Rear Spring Perches, Who's Running Them?
I just picked up a set of new/unused Wolfe Racecraft rear spring perches from a local guy that ended up not using them. Always thought it would be nice to have the rear adjustability for height. They came with 12" 170lb springs but I think these might be too tall for a 4th gen.?
So, who's running them and what spring height/rate are you using? Also, did you mount the perches up top or to the rearend? Any advantage or disadvantage for top vs bottom mount?
Mike
Mike
I checked out your build thread. You've done alot of work to that car. I'm prolly gonna go with a 10" 150lb spring but might go with an 8" depending on Charlies answer to my question above. Mines pretty low in the back already and I'd like to keep that stance. The top of the fender is just about even with the top of a 28"x10.50 slick.
Mike
Mike
