twin turbo 4.8 with powerglide. gear and stall questions
Restricted User
the car will weigh about 2900lbs with the driver
it will see some street time
looking to make 850 to 900 rwhp with twin 67mm magnum turbos
4.8 will have gapped rings katech rod bolts
custom ground boost cam from lloyd elliott 228/234 114 ish if i remember right
6.0 heads 2.02 valves ported by lloyd
looking to shift aroung 7400
car has 295/60 r 15s 28" tall i belive
with a power glide i need to know what rear gears would be good for this car?
what converter company i should go with?
what size of converter should i be looking at?
what first gear ratio in the glide?
i cant make up my mind glide or 4l80. i am leaning towards the glide right now. but i would like to hear your personal experiance with street driving on a powerglide.
Thanks for reading my post. sorry its so long.
Gear ratio probably 3.70-4ish .
First gear ,I would say 1.76 just to labour the motor a little more off the line to help spool quicker.
Stall speed, 3800-4200,again to flash a little quicker to develop boost
Converter company - Neal Chance
What type of car is it anyway
Beaudacious
Beaudacious
Restricted User
Beaudacious
Beaudacious
And sorry forgot to say but it is a 97 trans am.
