509 bbc
509 bbc
I am new here & very green wonder what you guys think this is wurt & HP it would make .Also can it be run on the street on pump gas thanks.
Dart big m block, billite main caps splayed
JE pistons
G2S rings
Scat crank 4340 knife edged and lightend from scat
Coated rod and main brgs
Moroso pan
Billite t chain and gears
ATI ballancer
SFI fly wheel
Comp cam solid roller cam .814 lift with 4-7 swap
Crane lifters
Comp cams stud guirdle
Crane moly rockers
Comp push rods
Brodex bb3x cnc heads 2,350 intake and 1.900 exhaust
World intake
1150 Hp dominator carb
Sheet alum valve covers
Arp head studs
JE pistons
G2S rings
Moroso pan
ATI ballancer
SFI fly wheel
Crane lifters
Crane moly rockers
Comp push rods
World intake
Arp head studs
WAY to much left out.
Compression ratio? Cam specs? Car? Gear ratio? Transmission?
Anything can be run on the street. Whether it will take race gas/E85 and idle at 1200rpm is another story.
It does sound like a stout motor
Car is 67 camaro tubbed 457 gears M21 right now but know would have to change tranny . Will try to get info on compression & cam specs thanks.
