Critique my 1/4 mile (it sux and i need good advice)
OK ive got awful times but i need specific advice...
slp headers cats y-pipe flowmaster exaust K&N
R/T.................... .909
60'..................... 2.402 (new tires) ive gots stock???
330.................... 6.288
1/8.................... 9.472
MPH................... 78.93
1000.................. 12.098
1/4.................... 14.291
MPH.................... 102.7
NOW GET THIS I ACTUALLY GOT LOWER TIMES BEFORE I GOT MY HEADERS...the guys didnt exactly ace the instillation, took about 3 or 4 more tries to get it right...I hope that its my bad driveing and not just the car... I actually had to get my pcm reprogramed becasue of a "bank error"
could their be something more that is draining my car's power
I NEED YALLS HELP...IM NEW AND I WANT TO GET THIS THING RUNNING RIGHT....ANY SUGGESTIONS ARE APPRECATED THX
!LS1 11 Second Club
Practice your launch. It's all in the 60'.
For street tires, feather the clutch. Launch max at 2500 rpms, but most likely around 1800-2000rpms. Also, on street tires, a 2.0 is not bad. That's where you should be. That would cut .6 seconds off your time.
For street tires, feather the clutch. Launch max at 2500 rpms. Also, on street tires, a 2.0 is not bad. That's where you should be. That would cut .6 seconds off your time.
Need to get the sixty foot down. Get appropriate tires as already mentioned. If possible get the slicks for maximum performance. The MPH will increase and the ET will drop proportionately with the drop in ET. IMO you can run in the 13.3 to 13.7 range. Cheers and good luck.
IMO slicks help a lot... but they also get you in grave danger of breaking something. Rear end, clutch, and driveshaft are all vulnerable when you put slicks on.
I ran a best of 14.3 @ 101 bone stock in my car, first time out with the 6-speed.
hey give me a decent list on good dry traction tires
-street radials ???
- I hear great things about nitto but what are the specific tires called and where is a good place to get them...does goodyear have any decent tires???
-street radials ???
For nittos there are 555R and tirerack.com and discounttiresdirect.com sells them.
Tire Rack is one of the sponsors------->
Nitto, BFG, and Mickey Thompson all make drag radials.
Drop your tire pressure.
Dont worry about tires right now. If your out just to have fun and want some better times just practice and drop your tires to around 23psi. That worked well for me on stock tires.
