Drag Racing Tech
ET Drag/ConvoPro Q
Old 04-28-2004, 03:35 PM
Humanoid's Avatar
Default ET Drag/ConvoPro Q
How big of a ET Drag will fit on a ConvoPro 15X7.5? Will it stick with my H/C,Yank SS4000 setup? 426RWHP.
Should I hold out and get 10" rims instead?
Old 04-28-2004, 08:26 PM
CamaroCain's Avatar
i am running 26x10.5-15 ET Drags right now, and they work well, only thing I had to do was get the rims screwed, found the tires were spinning, which makes me wonder about all the tires I have run before.
Old 04-28-2004, 10:42 PM
Humanoid's Avatar
What is your best 60' time on the ET drags Linda? Thanks
Old 04-29-2004, 10:24 AM
PewterZ28's Avatar
I have used the 28x10x15 ET Drags on 15x7.5 Convo Pros and it worked great. The side wall is pretty tall so you should hook. And you should be able to trap as high as 128+. Depending on what your car traps, you should be going through the traps close to the peak of your power band.
Old 04-29-2004, 10:36 AM
CHRISPY's Avatar
28x9 is a good tire for that rim (26x10 will also work)
26x8.5 fits perfectly. that is what I ran 1.50 on with the six speed
Old 04-29-2004, 12:21 PM
Humanoid's Avatar
28X9 ok with 3:23 gears? Thanks for the help.
Old 04-29-2004, 12:22 PM
CHRISPY's Avatar
I would go 26x8.5 with 3.23s not 28's
Old 04-29-2004, 12:30 PM
Bout'ItZ28's Avatar
i would go w/ either the 26/8.5/15 mt slick or the 26/9/15 hoosier slick w/ the 7.5" rim
Old 04-29-2004, 06:45 PM
CamaroCain's Avatar
Pulled a 1.48 with the tires spinning on the rims, haven't been back out to HRP since we got the rims screwed. This sunday looked pefect weather wise, but I see the Fun FART weekend is going on
Lynda
