Bogart, Centerline, or Weld?
LS1TECH Sponsor
I have a set of Centerline convo Pro front skinnies now. I am using stock Z28 wheels with 10.5 ET streets out back. I want to go to a 15" wheel in the back with the MT ET Drag and can't decide on what to do.
As I see it the options are:
1. Full set of Bogarts and new tires. But Jeg's web site specs an 8.5" wheel for this tire. Will the 9.75" Bogart be too wide? Also this is a very pricey option.
2. Get a set of Weld wheels and spacers. I already have longer ARP studs in the back. What size and offset will work, what spacer is needed, and is the grinding really as bad as all of the posts I have seen in the search?
3. Get Centerline Warrior wheels. From what I have seen in the search these will fit OK. I can not determine if spacers or grinding is involved. May be a good route but not sure.
4. Just get 2 15X8.5 Convo Pros and tires and call it a day. These should fit but I have heard that they may stick out a little. Also the wife does not like the Bling factor of these wheels, but it ain't her car.
K after all of that, I am open to opinion and suggestion.
Thanks for any help.
The Bull
Bogart makes some nice wheels. No personal experience with them though.
Depending on the Weld wheel that you are looking for you can get them in a variety of sizes. A 15x10 on a 7" backspacing fits really good. You can get these in the Aluma Stars. Aluma Stars do not fit with factory breaks or grinding! In the other Pro Star sizes I believe you can get these in a 7.5" backspacing and run them with a small spacer and it will fit over factory brakes with a little grinding.
Warrior wheels require more caliper work then a Convo Pro but the sizes are identical. A 8.5" wide Convo does fit but it sticks out a tad more then the 7.5 does. It's not really ideal and makes the back end of the car look fat and dorky instead of tucked. I had 8.5's on mine previously. You'll find the Warriors are exactly the same.
Short of narrowing your axles to get them to tuck nicer there are really only a couple options that would allow you to put a bigger tire and rim in there. You just have to go with what you like though.
I ruin the end of films...
The 9.75 Bogarts fit like a champ. No grinding on my LT1, front or back. If you do order some, make sure to specify LS1 for the fronts...there is a big difference.
Now, getting certain tires to fit....that's another battle in itself. I've got 275/60-15 BFGs on a set of D-10s and I had to do a little persuasion to get them in.
LS1TECH Sponsor
Ordered the Welds from Billingsly with MT ET radials. I did this on price more than anything. If I had no price cap I would have gone Bogarts. Thanks for the help.
I should have the ET radial in 2 weeks according to Amber. Could be fun.
well my buddy had his for a month and one front has already completely broken and one back one is flat spotted in two places and he only maybe put 150miles on them in that month back and forth from the track.
Rob
I have a pair of the 7.5" Convos for sale. Email me if interested. As stated, these are the only ones available in the Convo Pro lineup, that does not stick out. I ran a 28x10" ET drag on mine. I narowed the rear end & will be running the same rim on a 15x10" with 4" bs.
Originally Posted by Camaroholic
Yep that bites... but I daily drove mine on the street for months before the new motor went in. Mine still look (and work) great. Even drove on 'em (skinnies and 295/50-15 rears) to San Antonio for last year's Spring Break Shootout. Mine are Fluted Drag Stars.
bogarts break and bend easy though
I'm not stating the rims are foolproof and can't be bent...they most certainly can. Just as you can bend a weld or centerline rim, similar care must be taken with a Bogart rim so they are not bent.
Some of the Bogart series are much weaker and intended for very specific purposes. When someone uses them for a purpose not recommended, then most certainly, they will fail. This would be no different then someone going against the recomendation of say a nitrous shot...go past what is recommended for your engine...and boom! The rims are built for drag racing, thus the warnings of street use...just as other drag manufactures suggest. Just as any component that is used on your car, the more you stress it, the more likely it will fail.
Bogart P1 rims are a bit more over say a weld prostar or centerline rim. Our rims are CUSTOM built though and not in the same caliber as say a prostar or other mass produced rim not car specific. For this reason, it is hard to compare the products as they are not in the same league. Choose a higher quality weld rim, and quickly one would find out our prices are not as high as one originally thought.
I look at it as if your looking for a rim that works, not concerned with fitment issues, finish, quality of material and weight, then a mass produced rim is a perfect solution. This route will proove to be less expensive always.
If you are concerned with the above mentioned, then our rims would fit your needs.
It really comes down to what a person is looking for in a product. One wouldn' t purchase a Geo Metro and expect it to perform as a Ferrari, nor would they pay the same amount for the two items. This applies with the Bogart products. You get what you pay for.
Have a good day:-)
Steve
Pres.
LS1Tech Co-Founder
Well you have to look at the numbers.
Rims that are super light cannot take potholes and rough roads.
I have driven on Draglites and Pro Stars for years on the street but would never street drive Alumastars. My Pro Stars in back are 15-16lbs vs 11lbs for Alumastars.
15x7/10.5 works, maybe Harold has a deal that you would want.
I have never had a fitment or quality issue with the Centerline Convo Pro rims on my car now. No spacers, no grinding and very lightweight for a wheel you can drive on every day on or off the track.
I think Bogarts are great but there are definitely less expensive alternatives that work extremely well.
Just wanted to point that out to folks...
