What length springs for afco front shocks?
sorry, just realized that I didn't give enough info to get any help. Car is a 99 camaro. Some weight reduction, but will be getting an iron block and a supercharger in the near future. Right now it has stock springs and sits like a 4x4, around 29" at the top of the wheel well. I would like to get it down to around 25" at the top of the wheel well. Thanks
I'm pretty sure mine are 12" and 275lb/in
But honestly, they would probably be a little soft for an iron motor with a blower hanging off of it. So I would probably go for 300lb springs
I'd have to look to be sure. But I'm thinking mine are 31 threads from the bottom with a 275lb spring, and the black plastic valance under the front end is about 2.5" off the ground. It's pretty damn low
yeah, that is way different than mine. Mine with the 14" springs and the shock adjuster all the way down is higher than that. I'm using the racecraft style upper shock mounts with them, which is probably making about a 2 inch difference in the height. Looks like I need to go with a 12 inch spring.
