Drag Racing Tech
anyone running 27 inch hoosiers?
Old 05-08-2004, 11:14 AM
blackz93's Avatar
Default anyone running 27 inch hoosiers?
just wondering if they would fit on a stock susension T/A without any cutting like the 28's.
Old 05-09-2004, 03:51 PM
Bear's Avatar
U dont have to cut the suspension top get 28" tires to fit. The height will require some clearencing of the fender well. Its the width of the tire that will make u have to cut the suspension.
Old 05-09-2004, 05:25 PM
MIGHTYMOUSE's Avatar
i run hoosier 27*11.5's and the car is lowered one inch. i had to roll the fenders and beat in the fender well up at the front near the lca. but i did not have to trim the rear bumper.
these are on a weld pro star 10" wide and 7.5 b.s. with a 5/16 spacer.
http://community.webshots.com/photo/...74309555yhfgbT
http://community.webshots.com/photo/...96123496SpsCye
Old 05-10-2004, 05:21 AM
Moose's Avatar
I run them with no problems at all..
Old 05-10-2004, 10:58 AM
8 second mod
Noyzee's Avatar
I run 27x11.5 15's on Bogarts with no issues. I had to hit the wheel well a little but it looks fine.
Old 05-10-2004, 11:21 AM
2FAST4U's Avatar
Are you sure that when the tire is realy moving it doesn't rub up on the rear bumper! I have seen a few 27" that rub the fender on the street!
Old 05-10-2004, 04:31 PM
Savageite's Avatar
My 27"s would only rub the back bumber when I had my LCA's on the bottom hole. At the stock height it was fine.
Old 05-10-2004, 08:31 PM
blackz93's Avatar
thanks for the replies...
Old 05-11-2004, 10:42 AM
8 second mod
Noyzee's Avatar
My LCA are in the middle, and no prob, but i did pull them in a little with the adj ends
