What to expect?
What to expect?
What should I expect? I just ordered a new 8.8 rear (same ratio 4:10s) end, lower control arm relocation brackets, Spohn lower control arms, adjustable TA with drive shaft loop, and an adjustable panhard bar. What should I expect out of her. My current best 60' with the stock suspention and the Nittos is 2.0. Should I expect 1.8? How will the car ride. (I know I know throw it on and find out, but I cant wait, you know how it is). What exactly do relocation brackets acomplish. Whcih holes do I use for the strip which for the street. Thanks
I would say you could get better than that if you do it right. Slip the clutch just right, and if traction is good.
I would recommend about 18 lbs of air in the Nittos, that is where I got my best 60' times when I had my 6 speed in my car.
