Drag Racing Tech
build thread: t56/76mm real street/x235
Old 07-30-2014, 10:32 PM
  #61
studderin's Avatar
dose it have AC?
Old 07-31-2014, 07:41 AM
  #62
98blueSScamaro's Avatar
Originally Posted by 91lscoupe
**** yea man car looks awesome with new paint. congrats on record im sure it wont stand long you wil break that record for sure.seems like that junk *** monster clutch is taking it good unlike others say before lol.
I dunno about that. I had a 11 in monster and it took 7k plus hard hits off the line in a 3400lbs car no problem. Clutch never got noisy and always grabbed like new. It did so good in my drag car for a year I swapped it into are drift car and the same clutch no parts replaced is now kicking *** sideways and clutch kicking the **** out it with 15k for miles and 120 track passes. I say it's a good clutch. So good I am looking to upgrade with monster again for my new power and setup.
Old 07-31-2014, 09:14 AM
  #63
LS1Tech Premium Sponsor
ssvert99's Avatar
Great job Ray! MWC is glad to be a part of your build and record setting runs!
Old 08-01-2014, 06:18 AM
  #64
GMRACER13's Avatar
Originally Posted by studderin
dose it have AC?
You can see from the build pics that it doesn't have A/C. Unfortunately, there is no mention of whether or not 5th and 6th were deleted in the transmission which is typical in high horsepower track only builds.
Old 08-01-2014, 07:11 AM
  #65
blue99fbody's Avatar
He was being sarcastic. And 5th and 6 gear are still in the trans.
Old 08-01-2014, 07:38 AM
  #66
GMRACER13's Avatar
I know he was. It was a simple question, thanks for a simple answer. Your car is impressive and will undoubtably go even quicker.
Old 08-01-2014, 10:45 AM
  #67
Qwkss's Avatar
Whats next? Are they gonna complain you have no Cruise control?
Kick *** run Ray! Congrats as all your hard work has/is paying off!!
Old 08-01-2014, 12:18 PM
  #68
GMRACER13's Avatar
Who's "complaining"? I asked a simple question and everybody gets bent out of shape.
Old 08-01-2014, 11:36 PM
  #69
Zmg00camaross's Avatar
What's the paint code? Looks great!
Old 08-28-2014, 11:24 PM
  #70
91lscoupe's Avatar
didnt see it but heard the car went 50s tonight at 164??? thats moving out for sure
Old 09-02-2014, 10:34 AM
  #71
yes 8.54@164 cant wait for the good fall air to see where can get it.
Old 09-02-2014, 01:34 PM
  #72
Guitar's Avatar
That's moving! Have the slip and/or video?
Old 09-02-2014, 02:23 PM
  #73
here is the only video i have there are a few on facebook from cellphones from outside i forgot my camera. slip was
1.29 60'
5.56@130 1/8
8.54@164 1/4
Old 09-02-2014, 03:45 PM
  #74
SNLPerformance's Avatar
Woot!
Old 09-02-2014, 04:33 PM
  #75
When it was nitrous it looked much more violent ha.
Old 09-02-2014, 04:46 PM
  #76
LilJayV10's Avatar
That's rollin out for sure.
Old 09-06-2014, 11:31 AM
  #77
Gary Z's Avatar
Hi Ray, I’m hoping you are willing to share a secret with a fellow T-56, NMB Camaro owner if I promise not to break your record. In your in-car videos, it looks to me like you forcefully preload the shifter and that gears change only when the clutch releases. Is that an accurate description? It took me two months to rebuild my transmission and I've always been afraid to try anything (other than 7k clutch dumps) that might hurt it. Thanks, Gary
Attached Thumbnails build thread: t56/76mm real street/x235-blue02fbody-.jpg
Old 09-09-2014, 08:49 AM
  #78
ssvert99's Avatar
This thing is a beast!
Old 09-09-2014, 10:42 AM
  #79
im not sure what you mean by preloading the shifter i just put it in gear and hold my hand on it when launching so im ready to grab 2nd not using force on anything. i use the cluch on every gear change
Old 09-09-2014, 05:56 PM
  #80
studderin's Avatar
might not think about it, but some times if you put a little pressure of the shifter for the next gear, Not pulling at all just a little, more then nothing. then when you kick the clutch it goes right out if gear. noticed this with the 2step,the t56 gear think its from the helix cut in the gear (not strait cut teeth) holds them in gear when the power on going thu the gear set, so with the 2step cuts the power it takes the lash out of the gear ("unlocks" them) so it goes right out of gear into neutral, and into the next gear. I'm not a expert of t56 rebuilding,inside stuff just a idea, could be wrong. But noticed when you try to do a fast shift all in one motion when I try to "shift" before I'm off the gas. I'm too slow getting it out of gear in the super fast- clutch kick/pull gear, and end up in neutral. The little preload helps and saves the little .00004 sec head start of your arm to the foot. In the time window of the clutch kick. Not to go off topic, im so happy for ray, I can wait to get back on my car after these ray updates. And how hes killing it, blue99fbody is king badass ************
Quick Reply: build thread: t56/76mm real street/x235
