build thread: t56/76mm real street/x235
#81
might not think about it, but some times if you put a little pressure of the shifter for the next gear, Not pulling at all just a little, more then nothing. then when you kick the clutch it goes right out if gear. noticed this with the 2step,the t56 gear think its from the helix cut in the gear (not strait cut teeth) holds them in gear when the power on going thu the gear set, so with the 2step cuts the power it takes the lash out of the gear ("unlocks" them) so it goes right out of gear into neutral, and into the next gear. I'm not a expert of t56 rebuilding,inside stuff just a idea, could be wrong. But noticed when you try to do a fast shift all in one motion when I try to "shift" before I'm off the gas. I'm too slow getting it out of gear in the super fast- clutch kick/pull gear, and end up in neutral. The little preload helps and saves the little .00004 sec head start of your arm to the foot. In the time window of the clutch kick. Not to go off topic, im so happy for ray, I can wait to get back on my car after these ray updates. And how hes killing it, blue99fbody is king badass ************
#88
This is my favorite car so I need to ask another (possibly equally dopey) question. Now that you have the engine dialed in could you safely switch to a cast aluminum block? I'm thinking this could be a relatively inexpensive way to gain a tenth or two, especially with the smaller tires.
#89
#91
...i would not feel confedient in an alum block unless it was a resleaved erl or aftermarket $$$$$$. im pushing the limits of the stock iron block as it is. would like to go to a 6 bolt lsx block. plus in class racing i have a minimum weight anyway i have to be which i already have to balast the car up to so not worth the money for the rare time i get to try and take the weight out and make a hero pass
#92
Thanks. I was thinking of your mention of being 200 lbs overweight. I see now that was last year. You have been making hero passes - we don't expect you to make a Kamikaze pass. Thanks for showing everyone what is possible with a T-56. I hope a few others will be inspired to follow.
#94
Good stuff man. Got an lsx block for sale if you want it.
Been wondering if you lift off the throttle when you shift. Sounds to me like you do but I was not sure. The turbos are calling my name but not sure if I wanna go to all the trouble.
#95
shoot me a price on the block. and no i do not lift but what you hear is the 2 step cutting everytime i push the clutch to take the load off and help the trans live. and to be honest i would have done this a long time ago and gave up on the nitrous had i known this was gonna work this good and be this simple. i always said id never go turbo with the m6 but since real street takes a 20k+$ nitrous motor to compete i took the chance.
#100
Yeah trying to put the best heads intake cubic inches ect. to make power gets expensive quick.
Keep workin at, your gonna get it figured out and go faster.
pm sent.
