Drag Racing Tech
bad times
Old 05-22-2004, 12:05 AM
abate1224's Avatar
Default bad times
just got back from the track and i am pretty dissapointed at my times. please help. i know with the slicks i have i should at least get a 1.6 60ft. also i think that my trap speed is low for the hp that i have. all of my mods are in my sig
60ft 1.77
1/8 et 7.69
1/8 mph 91.87
1/4 11.92
1/4 mph 115.5
Old 05-22-2004, 12:20 AM
10 & 11 Second Club
Caveman's Avatar
Your MPH can be off because of heat, humidity or low baromiter. Also when you have good power the track prep is important. I went to Orlando Spin World 2 nights ago and they did not prep for test and tune at all. When theres an event they prep good and I run 1.50 to 1.55 60' all day but 2 nights ago my best 60' was 1.70 which hurt my et by almost .30 sec. So if you go when they prep and theres better weather you`ll pickup et and MPH.
Old 05-22-2004, 08:57 AM
abate1224's Avatar
thanks for the help, i am not that bad of a driver
Old 05-22-2004, 09:23 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Track prep is very important.
What track did you run at? What tires were you running?
Coach
Old 05-22-2004, 09:27 AM
abate1224's Avatar
i was at Ben Bruce Memorial (Evadale TX) and i was running some 27-10-15 hoosier slicks on 15x8 weld draglites.
Old 05-22-2004, 09:30 AM
What rpm are you dumping the clutch at?
What tire psi are ya running?
Man the track prep must have been bad!
Coach
Old 05-22-2004, 10:18 AM
abate1224's Avatar
i was running about 13 psi in the tires and launching about 4000.
Old 05-22-2004, 03:28 PM
10 & 11 Second Club
Caveman's Avatar
Be careful running low tire pressure on those tires, my car gets loose on the top end of the track if I run 13psi or less. I run my Hoosiers at 14 -16psi depending on track prep. Just saw a friend today that used to work at GM Express in S.Florida, he got out of shape going thru the traps at the Orlando SLP event last year. Luckily he walked away fine but the ZO6 was totaled.
Old 05-22-2004, 03:34 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,098 Likes on 721 Posts
I think you should be going faster, like 118mph, if you are full weight, your 1/8th mph shows room for improvement. I was going 93mph, 11.5, in an A4 back in 2000. I would be trying to up that 91mph to 93-94mph.
You might want to start tracking the weather and the weight of the car. If the weather like 3000 DA it's going to really affect the power.
Where are you shifting?
Old 05-22-2004, 11:11 PM
abate1224's Avatar
i am shifting around 6500 rpms
