Running out of 4th gear with 4:10,s
I ran a best of 12.59@ 110 2.0 60 on street tires in my 01 z28. And with 410 gears I'm at 6700 rpm in 4th when I go through. I even bumped the rev limiter right when I crossed. I'm scared if I run slicks I'll have to shift to 5th, should I swap to 373,s?
I have two questions here: you are trapping 110 so I'm "assuming" you just have bolt ons...no cam? If so you should not be revving to 6700...at all!! Secondly, this may sound like a stupid question but I have to ask anyways...are you sure the speedo is calibrated for the gears? This whole thing makes no sense based on the info that you've given us
My car was tuned and made 403 rwhp everything speedo was calibrated to the gears rev limiter set at 6800 witch I bumped at the trap no way I ran a 12.5 short shifting. Been driving this car for three years almost a year with the rebuild I know what 6500 feels and sounds like
You didn't mention about anything feeling weird ir off so I was guessing not
Also I have 4.10's as well and at 6800 rpm I'm showing right around 95 mph in 3rd. Not sure where you're getting 109
You're happy with a 110 trap in a 400wheel car? No offense dude but that's what a exhaust/gears car could do. My car traps 115 @ 3800 pounds with 3.90s and 386rwhp (before the 9").
I have a feeling you may be either short shifting a lot or again crossed in third. If so..you have a good amount left.
I have 4.10 gears in my trans-am (T56) and my speedometer is off by about 6 mph. My tach also reads about 200-300 rpm higher at idle than my actual engine speed.
If you really want to check it, you could just run it at half of the rpm (3300-3400 if your redline is 6700) in 4th and double the indicated speed.
It might not be the most accurate way, but it safer and less risky with regards to speeding tickets.
But either way, the stock gauges are not super accurate, at least in my limited experience.
