gto wheel hop killing 60ft
Hi, i purchased an 06 gto last year and the only things done to it were slp longtubes, intake and tune. the owner told me he had ran a 12.2 on slicks but i wasnt sure if it was possible with just these mods. i took it to the track for the first time yesterday and have attatched my best time slip out of the 3 runs. during the launch it wheel hops bad and i have to back out the throttle in fear of breaking my stock axles and stubs. my questions are what do you think i should be running on street tires considering i am trapping 111mph and how can i prevent the wheel hop. btw i was dumping the clutch and not slipping it. thanks and any input is greatly appreciated
i have drag bags on the car already. im going again this week but instead of dumping the clutch im going to slip it. would you happen to know what a decent 60ft on street tires is ? thanks btw
Race your car!
Unless you have a slipper clutch in the car, do not slip it you will cook it in a couple runs if you're lucky... if not it will get cooked immediately.
You need a bias ply tire, period. IRS, plus stick car, anything other than a bias ply tire is hopeless.
And plan on breaking 1/2 shafts, wrecking bushings, and all that. The irs systems just can't and don't deal with the stress drag racing puts on them. They're meant for nice ride and cornering. Not strait line performance.
Race your car!
Yup and it will absolutely hammer that clutch in about 2-3 passes doing that. They are not designed to slip.
If you want a clutch that's designed to slip a softloc mcloud will do that. It's set up with weights that increase grab with RPM and are designed to slip. They wear out extremely fast on the street and you can't drive with it really and expect it to last at all.
Stick car, you really have 3 choices. Dump it and deal with the destruction that happens, and just keep upgrading as parts kick themselves out of the car, put race car parts in that don't let you drive it at all, or accept that it's not going to ET for ****.
Pick one, because that's the deal.
Mine runs 6.5 in the eighth mile. Mickey Thompson 275 ET Streets or Hoosier QTP's. I have drag bags set at 18# and Viking adjustable shocks set at 8 clicks on compression. I have the stock diff and stubs, GForce axles----auto trans. I used to have the manual trans and the best 60' was 1.65, but not consistently. Mostly 1.75. Tires are a BIG part of the no wheelhop. I have none---knock on wood! Don't drive thru the waterbox unless you have skinny fronts and drag tires on the back. The water off the front tires will make you wheelhop. I never tried to slip the clutch, just don't rev it so high at the line and try to leave a bit softer, sometimes that results in a faster 60'. I'm not into breaking parts, that's why I suggested the things that I have tried. Have fun.
LS1Tech Premium Sponsor
If there is anything we can help you out with just let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Gto wheel hoppin bad
Hey guys. I've got an 04 6 speed. Shorty headers. Gutted cats. Resonator deletes. K&N full cold air. And Lou's short stick. No matter what I can't break. 14.1 my 60 foots suck. Help me out guys. 2.3-6 is my 60 foot. I've launched at multiple different rpms. 2k seems to work best
Le Goat,
I recommend you start your own thread for this.
What is the density altitude on your runs? Is your track at a high elevation? Is your car tuned for your exhaust? What kind of tires? Can you post some time slips? You can also check out my thread in the drag racing section on ls1gto for what I'm doing to try to improve my 60' times on stock power M6.
