Drag Racing Tech
2 Step without trans brake wiring diagram
Old 01-20-2017, 08:14 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Default 2 Step without trans brake wiring diagram
Wiring up a Lingenfelter LNC-003 2 Step without a transbrake. I want to activate it with a momentary switch and turn it off with a Lingenfelter STOV-001 MPH Switch. I am running a Holley Terminator EFI, so my mph signal will come from an Auto Meter Hall Effect Switch mounted on the transmission. A Dakota Digital SGI-5E will convert the signal for the Lingenfelter MPH Switch. Have I got this wiring set up right?
Old 01-25-2017, 12:50 AM
98 grmrpr's Avatar
Hey man.... your still kickin!!
Bump for ya, I'm no good at this but thought someone would have replied to it by now.
Old 01-31-2017, 04:32 PM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default Wiring diagram feedback
Diagram looks fine but note the following:
Based on the diagram, the secondary RPM activation will always be active (since +12 volts will be connected to the orange wire all the time). If you are using this as a high end rev limiter I do not see a problem with it.
Other Notes:
  • The indicator light will only be active if the toggle switch is on.
  • The line-lock will only be active if the toggle switch is on and the momentary button is pressed.
  • Primary 2-Step will only be active if the momentary switch is pressed, the toggle switch is on, and when you are below the set speed set on the STOV-001.
Old 01-31-2017, 06:36 PM
'Bird Director
y2k_ta's Avatar
Other Notes:
Jason, thank you for the reply!
I am wanting the components to operate as you have noted.
Scott
Old 02-02-2017, 05:30 PM
'Bird Director
y2k_ta's Avatar
Yep, I'm still around lol.
I'm a patient guy. It paid off cause I got the answers I needed. I hit the 10 year mark on my build next month.
Quick Reply: 2 Step without trans brake wiring diagram
