Drag Racing Tech
Defrost on a toggle?
Old 01-30-2017, 06:47 PM
JustAFooL's Avatar
Default Defrost on a toggle?
Deleted my AC when I done my turbo build on the car. Car is about to go through another byild
once all the parts show up and was needing more room for gauges and a couple toggle switches. I would like to use the area where the AC controls mount to do this.
Since the car is still street driven, I have to keep the defrost. I was curious if anyone has ever ran a switch for it? For instance, set the fan on high, temp on high, and the adjustment setting to defrost and have it all on one switch. May be a dumb question but I've never looked into doing it. I'm sure you guys that drag race all the time have seen or done something like this before.
Old 01-31-2017, 09:27 PM
JustAFooL's Avatar
Nobody??
Old 02-01-2017, 10:44 AM
imma_stocker's Avatar
What are you using for defrost? Factory heater core, ducts, and blower still in place?
Old 02-01-2017, 05:33 PM
JustAFooL's Avatar
yea, I never removed any of that
Old 02-02-2017, 12:30 AM
JimsNovaLS's Avatar
Should be no problem. Use a good heavy duty toggle switch, high speed blower draws some amps and will fry a cheap switch. A cheap switch could be used if you use it to control a 40 amp relay to power the blower fan
Quick Reply: Defrost on a toggle?
