Question on how to launch w/ vig3200
Hello,
I am having my transmisson rebuilt (after 16k miles), transgo shift kit, supercooler, and a vig 3200 installed tomarrow and in am really antcipating taking it to the track sat.(june 8th). Do you guys have any advice on a good launching technique? I will be using nitto's or yokohama A032r's depending on what classI run in. Any advice you guys can give me would be greatly appreciated.
Another thing I should mention is that our local track is only a 1000ft track, if it makes any difference. Any estmations on how much time I should drop after this. (current best is 10.51@98 1000ft.)
Re: Question on how to launch w/ vig3200
my vig (and most others i hear) dont like to be stalled up too high...pretty much idle to 1000 rpms is good.
drive around the waterbox, back into it, roll out of it and do your burnout on the dry pavement with your tires wet. make sure they get smokey <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Same here,
I've tried launching my Vig 3200 in 250 RPM increments from idle up to 2500 RPM and it seems to respond best at 1000 RPM and my idle is set at 900 RPM. So now I just launch at idle, best 60ft 1.684.
Mark
Mark
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by z28kid98:
<strong>launching at idle gets me consistent 1.71's
launching at 2k gets me consistent 1.68's
that's just the way it works for me on e.t. drags. every car is different. mine just likes it higher.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">how do your ets compare though? i find that i get a little better 60',but et doesnt really get better.
i checked my slip and my 1000 was 9.95 with a vig3600
its very simple to launch so just do the burnout DRIVEATA stated! Once you get to the tree, just listen to the car and rev up slightly(listen to motor). I seldom look at the tach cause im watching the tree and thiking about my launch <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I did glance one time and i always seem to be around 1000-1250. I've tried dead idle launches but i cant hook with nittos, so i would love to see the 60's there <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
make sure you have 19psi in both tires!! and recheck after each pass! because your pressure will go up from 19 to say 22 and get higher with each burnout.
but just get up there and pratice! I went from 1.70's to low 1.60's and upper 1.5's learning how to launch!! Make sure the track is prepped and dont give up.
Nittos will hold 1.5's and low 1.6's easy, so if your not hooking its not the tires, its the track. Just play with your launch rpms <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I learned to launch on Nitto's basically from 98TAauto and the Colonel plus some others. If you used nittos--make sure you do a long burnout and proceed to the line immediately. My best 60' times seem to come when I launch at 2200 RPM's. After H/C and ET streets, sixty foot times dropped to 1.602 and 1.608. Maybe eventually I will catch 98TAauto--HeHeHe. Now I launch car from 1500 to 1800 RPM's on my 3200 vig. I suggest you do a search on 98TAauto number because he has many good suggestions on vig. convertor and nittos tires. He is pretty good with his setup. Good luck and cheers.
Thanks guys, I really appreciate the advice. The stall didn't show up on the UPS truck today, but they said it will be here for sure tommarow (maybe). I've got the burn out technique down pretty good, best 60ft of 1.89. I counted some time slips and the previous transmission lasted 300+ passes (2 years) at our local track. Does any one know if a rebuilt will last this long? Thanks again for the advice.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DriveATransAm:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by z28kid98:
that's just the way it works for me on e.t. drags. every car is different. mine just likes it higher.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">how do your ets compare though? i find that i get a little better 60',but et doesnt really get better.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">my e.t.'s are similar, with the 2k stall being a little bit better (couple hundreths)
DO NOT, I repeat, DO NOT go into the water box with treaded tires. ET Streets or slicks only.
The tread will pick up water and sling it into your fender wells, then drip onto the track.
That's a quick way to **** alot of people off.
I'd imagine that some tracks might let you run nittos in the box, but you better ask first.
BTW, just LOVE my ST3500. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NASSty01:
<strong>DO NOT, I repeat, DO NOT go into the water box with treaded tires. ET Streets or slicks only.
BTW, just LOVE my ST3500. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i disagree. and are you telling me slicks wont throw water anywhere <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
