Is dynabat/hawker good for a daily driven car?
Re: Is dynabat/hawker good for a daily driven car?
It should work fine. However it's probably not wise to run accesories for long with the ignition off (Stereo, headlights, Manual fan switch etc).
I have had a dyna bat in my car for a year now. I've only had to jump the car once and that was when the car sat for a week during record low temperatures. No problems followed though. Also, You cannot just leave the headlights or radio on though, for this is sure to kill it.
You can purchase adapter posts at any automotive parts store. Mine were called "marine adapters" and they simply slide over the post. Once there they extend up about an inch and have a threaded hole the size of the stock battery connections.
Can someone tell me the best place to purchase one of these and anythign else needed?
Thanks guys.
Thanks guys.
Which one did you guys get?? the genisis or svr-14.
Will it hold a charge well enough to load ls1edit files??
13.5 and 11.5 are some awesome weight savings!!!!
