brake rotor questions??
ok guys I need new rotors mine are warped as all h*ll. I have prostars and use spacers as of now. I had planned on grinding and not using spacers.BUT:
I would like some drilled/slotted rotors(just for looks, I am not a big autoXr etc). SO are there any made that will still allow use of prostars? with or without spacers?
Re: brake rotor questions??
Eradispeeds or slightly thicker but the same diameter. You should be able to use your prostars without problems. Thats what I have <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Eradispeed would be a possibility. They are expensive, but are very nice from what I here. Consult with Thunderracing to get the particulars. I almost bought them to reduce rotational weight, but you lose only a pound or so on the front for each wheel and I lost interest. Cheers.
