Need lightweight hood info...
Who makes the lightest bolt-on fiberglass hood?
Will I need new 'pistons' or springs for it?
I don't care about cowl size.Stock is fine.It just needs to be light.
Thanks.
I don't really want a pin on hood.
I know they're lighter,I info on those.
Just looking for bolt-on info
Thanks.
SSU Moderator
Re: Need lightweight hood info...
www.vfnfiberglass.com
You should be able to use your stock equipment with just some different struts.
Ryan
<small>[ June 20, 2002, 09:20 PM: Message edited by: Ryan ]</small>
Ryan
LS1Tech Co-Founder
Sean, VFN is in Addison near Street Stuff. Glasstek is in the same complex as FLP.
I think the reduction would be about 20 lbs if you go to a stock appearing bolt'on hood. I think you can continue to use your stock hood struts but I'm not sure.
