Favorite wheels for drag racing?
I'm looking to get a pair of 15" wheels for 26-10x15 ET Streets or P275 / 50 R15 BF Goodrich drag radials; I assume they can fit on the same size wheel - what is the preferred wheel?
I've seen Convo Streets mentioned; I have to be able to drive them on the street (can't change at the strip)
Any suggestions? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
It's an M6 car with minimal bolt-ons; so low 13's.
Have never been able to hook with stock tires or Firehawks but I have trap times of just a tick under 109 MPH so I'm sure the power is there.... <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Re: Favorite wheels for drag racing?
i have 7.5 wide convs with 275 x 50 x15 nittos with 3000 stall YANK , they are not real flat( a little round )but they fit inside the wheel well. 8.5 rims will stick out an inch, they will not look good!I have cut 1.70 -1.73 60 fts on a well preped track , and the NITTOS are not bad in the rain. ET streets are not wider tires.
how much offset to run 8.5" wheels without hitting anything or having to hack up the fenders/rear bumper/etc.?
275/50 should be wide enough
SSU Moderator
Weld's rears: 15x8" with 5.5" BS
Centerline rears: 15x7.5 with 5" of BS
both tuck in and are light enough. everything up to about a 9" slick on the C-lines and 10" slick on the DL's. 10.5" ET streets will work fine on both. if you want mroe meat or just a better contact patch go with 15x10" Welds with 7.5" of BS.
