01 LS1 in 91 Z28: TRACK TIMES!!
<img src="http://www.speartech.com/91Z28LS1_drag_launch01.jpg" alt=" - " />
I took the LS1 91 Z28 to Muncie Dragway last night for some baseline runs. The conversion and buildup of the car is at:
http://www.speartech.com/coproj-1991ls1.html
The weather turned decent so I thought this would be a great chance to see how everything was working. I was happy! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Everything worked well except none of my burnouts were any good. The first run I missed getting in the water. After that I would get them wet, but as soon as I would get them spinning, the car would push forward too much. I wanted a good smokey burnout but never got one. Anyway, I was very pleased with the performance of the car.
I made 5 passes total.
#1) 12.060 115.25 1.800 60'.
#2) 12.151 115.06 1.873 60'.
#3) 11.920 115.14 1.729 60'.
#4) 11.926 115.35 1.754 60'.
#5) 11.921 115.36 1.741 60'.
I think there is certainly more to be had. I have a set of 3.73 gears to replace the 3.23's, and maybe a line-lock or something to get better control over the burnout situation. I've read that the Hoosiers like a good burnout and I could definitely feel a slip and grab with each launch. I had a Grand National about 6 years ago that ran a best of 11.84 and this car is probably going to beat that the next time out! FUN STUFF!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
<small>[ July 12, 2002, 10:26 AM: Message edited by: Speartech ]</small>
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
SSU Moderator
Re: 01 LS1 in 91 Z28: TRACK TIMES!!
3.73's and a good burnout with a line lock will get them 60's down to easy 1.6's with that converter. good luck with the car....i used to have a 92 RS (25th anny) and would have loved to see it with an LS1/Yank combo <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks guys. I was pretty pumped about having 11.9's as a starting point!
I have not weighed the car yet, but will shortly.
PSJ: I'm shifting at 6600 trying to get the most from the cam.
Below is a list of mods, copied and pasted from the buildup page on my website:
1991 Z28 Camaro
2001 LS1 engine w/4L60E transmission
Speartech Fuel Injection Systems custom plug-n-play wiring harness for 3rd Gen F-body
Speartech Fuel Injection Systems performance PCM programming
LS6 intake manifold (std. w/2001 and up LS1 engine)
Comp Cams cam .566-.566 lift; 222/222 duration @.050; 114LSA
Comp Cams 918 valve springs
Comp Cams titanium retainers
ASP underdrive crank pulley
Aeromotive EFI adjustable fuel pressure regulator
MAC off road Y-pipe custom fit to car
Flow Tech 3" exhaust cutout
Yank Thruster Pro 4400 torque converter
HD transmission cooler
2000 T/A aluminum driveshaft
Jegster driveshaft loop
LG Motorsports tubular lower control arms
BMR control arm relocation brackets
Right rear spring airbag
Weld Draglite 15x3.5 front wheels with Kumho 165R15 tires
Weld Draglite 15x8 rear wheels with Hoosier Quick Time Pro 27x10.5x15 D.O.T. drag tires
1991 Z28 Camaro
__________________
www.speartech.com
www.speartech.com
Nice! You have nearly an identical set-up to me. My car ETed a bit better because my short time was a bit better. With a 1.60 short time, we should both be in the 11.65 range I think!
NICE!
NICE!
That is absolutely awesome. If it was black, I'd be asking how much you'd sell it for. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I look forward to hearing how things progress.
Good luck!
Good luck!
Dude, that is so badass!!!! I bet everyone was thinking "blah just another 3rd gen, probably run mid 14s"
Well, time to go look for a black with silver trim 3rd gen..... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
J.
J.
Whoo Hoo!!! <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
i think we need to send that back in time to pick on the 5.0's <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
sweet times and car!!! Im not a huge 3rd gen fan, but now i changed my mind
Thanks for the nice words guys! And to 98TAauto, I'm glad I've made a 3rd Gen fan of you. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
After looking at the times and MPH of various cars on the board, I've gotta think the 3rd Gens are quite a bit lighter than the 4th Gens. With every run being 115+ with no head work and thru cast iron exhaust manifolds, it leads me to believe it's low weight rather than high horsepower. One guy in a C5 running 12.8's couldn't believe I was running 11's with no headers.
I did get a line-lock yesterday and will try and schedule the 3.73 install next week. Then back to the track.
I will post when I get it weighed.
__________________
www.speartech.com
www.speartech.com
They are SIGNIFICANTLY lighter....
my shipping weight of my 89 IROC-Z with ALL power options and T-tops was like 3350lb
so with driver and all fluids and no weight reductions you're looking around 3600lb, pretty nice if you ask me
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Nice numbers first time out.With that set up that car outta run some low 11's or even some high 10's in decent weather and with a little better gear.
<small>[ July 21, 2002, 02:47 AM: Message edited by: ALLBORENOSTROKE ]</small>
