what gears should I run in a 9"
11 Second Truck Club
What gears do i need in a 9" with m6 my dyno was a little over 500rwhp with pump gas car weight is 3900 I was thinking 3.70 is that about right? I am running 26x10.5 et streets.
<small>[ July 28, 2002, 10:20 AM: Message edited by: 2bseen ]</small>
Re: what gears should I run in a 9"
Depends on how much driveability you can stand to lose with a steep gear, your tire size, your max RPM, and your expected trap speed.
FWIW, a 26" tire and 3.70 gear is good for 136mph @ 6500rpm assuming no drivetrain slippage (not really a factor for you since you have a M6), and no tire growth.
There's a handy gear/speed/rpm calculator here.
hoping to trap at 125-128, also I want to be about to drive anywhere on street. With 3.70 gear and shifting around 6200 will I have to shift to 5th.
thanks tony
thanks tony
